Print .exe files
Print .exe files - Problems to print a .exe SMath file made in old version - Messages
#1 Posted: 2/1/2019 7:36:32 AM
Hugo Gatti
Hugo Gatti
0 likes in 2 posts.
Hi! I´ve been facing some problems to print a .exe SMath made in a old version.
I have installed in my computer the latest stable version (0.99 6884) and when I try to print the file appears an error message of gdi+ generic error.
The only issue is this, despite this, I can use the file without other problems.
Do you know how can I fix it? I´m not sure in which SMath version it has been made, I only know that it was in a old version.
#2 Posted: 2/1/2019 10:50:26 AM
1,442 likes in 2,934 posts.
The only way you have is to generate a new executable using a more recent SMath Studio. Once an executable is created it is independent from any installed applications and/or plugins; this means that you don't need SMath Studio when you run the executable, and also that every feature (as well as any bug) will stay in that executable forever.
#3 Posted: 2/1/2019 11:27:33 AM
Hugo Gatti
Hugo Gatti
0 likes in 2 posts.
Thanks!
