Stable: SMath Studio 0.99.7030 (01 April 2019)
Stable: SMath Studio 0.99.7030 (01 April 2019) - Messages
#1 Posted: 3/31/2019 7:28:17 PM
2,345 likes in 4,059 posts.
List of changes (between 0.99.7016 and 0.99.7030 versions)
Improvements
  • Text Region improved to have full support for Fields;
  • Fields can be used in Area title and Regions Description now;
  • Insert matrix dialog improved to allow switching from rows box to columns pressing arguments separator on the keyboard;
  • Rendering of Worksheet Pages when Multiple Pages turned on improved.
Corrections
  • Displaying of full-page background images corrected in Printing Bounds document mode;
  • Rendering of the Documents changed for Pages View and Printing Bounds document modes when backround image is set (full document pages shown in this case);
  • Search results update when search box becomes empty corrected;
  • Support for Unicode chars improved to avoid double encoding of the Unicode entries;
  • Work with Worksheets where content is written out of bounds of the logical Pages (in non-Pages mode) fixed;
  • Switching between pages when Headers/Footers in edit mode improved for situations when Headers or Footers content differs on different pages;
  • Errors displaying corrected in case of inline calculation of the definition requested;
  • Calculation accuracy improved for power and boolean equal operators;
  • Location of the Worksheet Pointer corrected on adding new Worksheet Page by click;
  • Hotkeys for Greek phi symbols restored to be the same as ones introduced initially;
  • Fixed issue with generating random file name on using splitted window feature;
  • Application crash fixed happened sometimes when using splitted windows;
  • Possibility to disable evaluation for Area Region restored.
Miscellaneous
  • Automatic switch to special characters mode removed for Math Region;
  • Refactoring;
  • UI performance improved;
  • Tooltip text shown on Worksheet scrolling corrected for complex document layouts;
  • Minor improvements to Insert Function dialog.
Download
SMathStudioDesktop.0_99_7030.Mono.tar.gz (1.36 MiB) downloaded 48647 time(s).
SMathStudioDesktop.0_99_7030.Setup.msi (2.24 MiB) downloaded 126133 time(s).
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
Other files
8 users liked this post
NDTM Amarasekera 3/31/2019 11:36:00 PM, bdrunagle 4/1/2019 3:36:00 AM, sergio 4/1/2019 5:33:00 AM, Davide Carpi 4/1/2019 6:04:00 AM, Igor Skarine 4/1/2019 10:45:00 AM, Вячеслав Мезенцев 4/1/2019 6:36:00 PM, Serg 4/5/2019 1:17:00 PM, Василий Николаевич Храмушин 4/30/2019 9:48:00 AM
#2 Posted: 11/26/2019 1:34:41 PM
Artiom
Artiom
0 likes in 2 posts.
Is there a way to open several instances of the app in that version? Not like a few windows with different documents, but few system windows with different documents. Looks like it doesn't work now, but worked in previous version. Now it's super inconvenient because it's impossible to work on few monitors in different files at the same time.
#3 Posted: 11/26/2019 8:20:36 PM
Not clear what you could do before and not anymore.
When you open a PC session, you have nothing yet
At this point: click on the Smath icon TaskBar ... bingo Smath.
From there, you can open any Smath work sheet from wherever
in the PC box as you have a single Smath session.
Now, if you want another Smath session, double click on the
Smath icon in the DeskTop ... not TaskBar.
You then have a 2nd Smath session identified page 1.
Do that as many times as you want independent Smath sessions.
Now, to reach those Smath sessions, hover on the Smath icon
on the TaskBar ... click on the one you want identified page 1.
From the Smath menu "Open", browse for the document you want
from wherever in the PC box. Do same for the other not yet opened.
Now, you have as many Smath sessions as desired for each of
your active screen for multiple consultations.
But, all that is BS & BK [Bull Shit & Book Keeping].
Open documents from a single Smath sessions ... open any number,
I know no limit. From your individual screen just consult the
one in cause. Just works great Win 7, SS 6179.
It can be done other wise.
#4 Posted: 11/27/2019 7:41:54 AM
1,139 likes in 1,805 posts.
Hi. I ask for this feature, which is good for low resources systems, because SMath is some slow starting. I guess that it's in the c:\Users\##USER##\AppData\Roaming\SMath\settings.inf the option, but can't find where.
Check this: https://en.smath.com/forum/yaf_postst17103_About-messages-and-smath-instances.aspx
Hope this helps.
ALvaro.
#5 Posted: 11/27/2019 10:32:09 AM
Does it work this way for you ?
3 double click on the Smath icon Desktop.
The first Smath instance takes > 1 min
2nd & 3rd instance 45 sec.
Now, you have 3 Smath sessions, each one to be filled
from your main Smath documents directory
SS 6179 Win 7
#6 Posted: 6/9/2020 4:37:52 AM
fedeghi
fedeghi
25 likes in 112 posts.
Hello, new stable builds have not been release for a while now (more than one year).
I would like to know if future plans for development on smath are still ongoing and, in case, if a new stable build is going to be released?
Thanks
Bye!
#7 Posted: 7/16/2020 4:58:00 AM
Everything is OK. It is not a first time in a project's lifetime when development was paused.
Currently I've almost finished work on my other projects so plan to return to SMath very soon.
4 users liked this post
sergio 7/16/2020 6:02:00 AM, IVR 7/16/2020 6:50:00 AM, overlord 7/16/2020 8:50:00 AM, Igor Skarine 7/17/2020 3:00:00 PM
#8 Posted: 7/16/2020 8:51:49 AM
601 likes in 1,382 posts.
I had begun to worry about you dear Andrey.
Since so much bad news is happening in 2020...
It is good to hear you are doing well.
#9 Posted: 7/16/2020 12:00:08 PM
otto daniel
otto daniel
0 likes in 4 posts.
Thats great andrey, I honestly was fearing the worst had happened.
btw could you look into the no symbols shown in toolbox bug we linux users are facing?
