Tab Key Is Not Working
Tab Key Is Not Working - Mono 2.10 Ubuntu 12.04 Can't Select units with "Tab" key - Messages
#1 Posted: 10/12/2012 11:33:52 AM
Ninoslayer
Ninoslayer
0 likes in 1 posts.
Hey. I liked so much Smath. But I have a problem. It is not vital but if i can solve it i will write my equations very easily. I can't select the unit with "Tab" key. For example when I will write 5*m/s^2 and when pressed "m" it shows me meter to select but for this i must double click to "meter" or press tab. When I double click it works perfectly, but when I press "Tab" for quick input It does not do my job. I use Ubuntu 12.04 with mono 2.10. If someone can help me i will be very pleased.
By the way; I ran program from terminal but it does not produce output.
#2 Posted: 11/15/2012 10:10:24 AM
Gluhm
Gluhm
0 likes in 3 posts.
I can confirm this problem. Using Ubuntu 12.04 with latest mono-libraries.
#3 Posted: 12/17/2012 3:57:42 AM
masterRHK
masterRHK
0 likes in 1 posts.
I have the same problem.
I used SMath on windows in the past, which I learned to use and enjoyed AND the tab key worked for units.
I have become a user of Ubuntu, I am using Ubuntu 11.04 with the latest mono and loaded SMath, the TAB DOES NOT WORK TO INSERT UNITS. It spoils SMath and my interest to use it.
I need a solution, help help!!!!!
#4 Posted: 9/21/2013 7:34:54 PM
fractal618
fractal618
0 likes in 1 posts.
I also have this issue with Linux Mint 15.
It seems to be a problem with Mono, I will post the bug on their forum as well.
#5 Posted: 7/11/2026 4:30:54 AM
Lucky
Lucky
0 likes in 6 posts.
I have same problem. tab key not work
#6 Posted: 7/11/2026 10:01:04 PM
601 likes in 1,382 posts.
Interesting, I am using latest Smath (1.5.0.9678).
With latest mono release in Void Linux repository (MONO 6.14.0).
My current setup doesn't have a Tab Key issue.
