"Else" statement not appearing when I choose "if" from the programming pallete
"Else" statement not appearing when I choose "if" from the programming pallete - Problem using the if function from the programming pallete - Messages
#1 Posted: 8/6/2022 12:59:16 PM
James Mazon
James Mazon
0 likes in 2 posts.
I´m having problems with the if function on the programming pallete. When I choose "if" from the pallete it just shows two lines, there is no else anymore like on the image in the attachment. If I recall correctly the else statement used to automatically appear when you choose the "if" function from the pallete. Could someone help me understand what´s happening?
Show Spoiler
#2 Posted: 8/6/2022 2:03:26 PM
127 likes in 342 posts.
First of all, check in Tools-Option-->Interface-->Arguments separators which setting you set up. They are possible "," "." ";".
Suppose it is ";".
In the placeholder digit once ";" to get Else or ";;" to get Elseif
#3 Posted: 8/7/2022 12:12:44 PM
James Mazon
James Mazon
0 likes in 2 posts.
Thank you! It worked
