Beta: SMath Studio 0.99.6877 (30 October 2018) - Messages
Changes introduced in current build 0.99.6877
Improvements
- Background dialog improved to show currently chosen image on dialog open.
Corrections
- Application start failure under Mono runtime fixed;
- Fixed issues when Dynamic Assistance list does not show built-in items;
- Environment specific rendering issues of the Dynamic Assistance list fixed;
- Accuracy of work with complex numbers improved;
- Scrollbar bookmark related to current cursor location corrected to always show actual cursor position.
Miscellaneous
- Added ability to make Header/Footer different for selected page (see Insert > Header and Footer menu);
- Rendering of Header/Footer during export to PDF and other formats fixed;
- Interface translations updated;
- Refactoring.
Download
SMathStudioDesktop.0_99_6877.Mono.tar.gz (1.35 MiB) downloaded 2462 time(s).
SMathStudioDesktop.0_99_6877.Setup.msi (2.22 MiB) downloaded 4947 time(s).
This time it puzzled me again. Please see how it performs now.
The SS prints the result of maple(expand(...)) normally,
but after assigning the resulting expression to the variable nnn,
it failed even to display nnn.
What means "Not defined" if it has shown the correct result before?
example_5973.sm (10.7 KiB) downloaded 1602 time(s).
Wrote...
Hi. It means that can't recalculate because the use of sums and products. For force the recalculation as it is needed, can enclose the num definition by a line:
