differential equations - solve differential equations - Messages
If you can please explain the various steps to be able to solve the differential equation in the picture.
I am interested in deriving the function phi (t), what do you need to know to solve the differential equation?
Thanks for your patience
Documento2 DE [explain more] (25).sm (48.29 KiB) downloaded 1059 time(s).
Wrotesorry but I have practically no experience with this program and I find it difficult to understand the functions.
T
The setup to numerical DE solver is same as Mathcad,
even superior as it takes the parameters as vector.
Use p[1,2,3] for those parameters.
Up to what you proposed before: you don't have a DE
Those parameters are non-sense as they send the system in the zillion domain. Get that DE from the teacher, a bit of abstract would help.
Documento2 DE [explain more] (25).sm (71.7 KiB) downloaded 1052 time(s).
Wrote...
Hi. Usually we want know the ode and it's initial conditions. In your case you have boundary conditions, which can be solved by the shooting method.
Hope this helps.
motocicleta.sm (48.71 KiB) downloaded 1244 time(s).
motocicleta.pdf (203.43 KiB) downloaded 781 time(s).
-phi(t = 0) = 0.146
-phi'(t = 0) = 0
WroteMy initial conditions are:
-phi(t = 0) = 0.146
-phi'(t = 0) = 0
For a Cauchy problem it's more easy.
motocicleta with IC.sm (37.14 KiB) downloaded 1225 time(s).
motocicleta with IC.pdf (136.74 KiB) downloaded 805 time(s).
regards
1. What maths are given/invented: a formula ?
2. From that formula, what is next
So, you have a formula and an objective project,
i.e: a pretty short work sheet not yet circular in the blue.
WroteThis is an offer ... accept/reject ... go back to "square zero"
I appreciate the advice. I'm trying to learn
WroteI appreciate the advice. I'm trying to learn
Just give the formula that you were given.
or make an image from source ... learning is after.
These two examples are Cauchy integration. They have no formal symbolic.
A discrete integration is possible via the module rkf4(y0,x0,x1,n,f).
From there: easy to get the discrete derivative.
ODE Cauchy Project.sm (27.38 KiB) downloaded 1273 time(s).
I tried using Simpson and Romberg's recursive methods, but without getting a solution.
Where am I wrong?
PROJECT.sm (69.12 KiB) downloaded 1294 time(s).
WroteHi, sorry if I bother you again. I'm trying to integrate a function, the function in question is psi''(t) in order to derive psi'(t).
You have phi in your document ... psi is a built-in function.
So, if phi''(t) is the 2nd derivative ... then the derivative
is simply the integral. To expedite fast: done discrete.
If you have questions: please re-post this document.
Cheers ... Jean.
PROJECT [1].sm (30.82 KiB) downloaded 1043 time(s).
WroteYou have phi in your document
.... in fact you have PSI''(t).
Maple does not find an explicit integral.
PROJECT [1].sm (21.91 KiB) downloaded 1066 time(s).
Where am I wrong?
Hi. You can use any Runge Kutta solver for integration.
Also, you can use SMath int procedure, but it's very (very) slow:
For the theory, remember that you can integrate (with definite integrals) both sides of an equation and get an equality too, which don't work with derivatives.
PROJECT.sm (74.9 KiB) downloaded 1275 time(s).
But now I can't calculate the ratio in the picture.
The error says, "The matrix must be square"
PROJECT.sm (57.24 KiB) downloaded 1282 time(s).
WroteHi, I have calculated the function psi '(t) through dn_GearsBDF.
Result from numerical ODE solvers is a data set.
Generate an interpolation scalar to 'x' ... then plot.
@ the end of the document ... more questions: -this one.
PROJECT (1).sm (74.9 KiB) downloaded 1271 time(s).
