SMath Studio 0.97.5737 (17 September 2015)
SMath Studio 0.97.5737 (17 September 2015) - Messages
#1 Posted: 9/16/2015 7:08:52 PM
2,343 likes in 4,044 posts.
New SMath Studio 0.97.5737 available
Latest changes (against to the latest nightly build: SMath Studio 0.97.5576)
  • Scrolling within Reference Book restored;
  • Added ability to paste inside text element of MathRegion;
  • Fixed issue appeared when newer version of built-in plug-in required for worksheet opening;
  • Fixed issue when items from Menu > Insert not updated after new plug-in(s) installed;
  • SS-170: Unwanted automatic Image region resize on file open to fit into printing bounds fixed;
  • SS-2268: Broken equation on inserting factorial or boolean not operators for selected equation's part fixed;
  • Displaying sum(1) and int(2) functions corrected;
  • Internal: Symbol for 'minus/plus' operator changed from '%';
  • '%' symbol can be used for variables, text and units inside Math region now;
  • Handling of erorrs on evaluation performed by Custom Regions plug-ins improved (stability improvement);
  • Language files updated;
  • Regactoring.
Additional changes (against to the latest stable release SMath Studio 0.97.5346)
  • Ignore Units feature implemented for Math Region (required for engineers in some cases, when equation contains constants without specified units);
  • High definition scrolling finally supported (scrolling was not possible with some Microsoft mouses);
  • Added ability to delete installed plug-ins;
  • Dialog with failed to load plug-ins allows to update them without opening Extensions Manager;
  • Trailing zeros option of Math Region performs evaluation after change;
  • Scrolling to focused region significantly improved;
  • Displaying of simplification results improved for some cases;
  • Replacements of units on copy/paste fixed (f.e. 'g->'g.e);
  • Various critical errors fixed happened on paste of inconsistent equation part;
  • Fixed calculation exception happens sometimes when working with plus-minus and minus-plus operators;
  • Critical issue on closing worksheet fixed;
  • Saving to .SM/.SMZ improved;
  • Ar unit usage corrected for German localization;
  • Icon for beta-extensions improved;
  • Improvements for developers done;
  • Experimental support for default output units system choosing implemented (WARNING: not all conversions available yet);
  • Esperanto language added;
  • Thai language added;
  • Languages updated;
  • Refactoring.
System requirements
  • Desktop (Windows):
    Framework: .NET Framework 2.0
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Free Download
Tutorial
Other files
7 users liked this post
Вячеслав Мезенцев 9/17/2015 1:00:00 AM, Davide Carpi 9/17/2015 3:56:00 AM, NDTM Amarasekera 9/17/2015 7:48:00 AM, sergio 9/17/2015 9:45:00 AM, ioan92 9/17/2015 11:33:00 AM, Martin Kraska 9/20/2015 4:59:00 PM, David Thomson 1/15/2016 8:21:00 PM
#2 Posted: 9/17/2015 10:56:17 AM
uncblue
uncblue
2 likes in 18 posts.
As always, thank you for your hard work.
I'm looking forward to the latest changes.
#3 Posted: 9/17/2015 11:00:17 AM
9_82abZ2
9_82abZ2
0 likes in 7 posts.
I just updated to this version and I had the following plugins fail to load:
-Checkbox Region
-Combobox Region
-Conditionally Formatted Label
-Data Exchange
-Modeller Region
-XLSX Import/Export
-Script Region
-all of my custom plug-ins
I was able to resolve these errors immediately for everything except:
-Script Region
The 'error' that was being flagged for all of these plugins were:
A strongly-named assembly is required. (Exception from HRESULT: 0x80131044)
Just so people have a 'heads up'
#4 Posted: 9/17/2015 11:47:03 AM
-Checkbox Region
-Combobox Region
-Data Exchange
-Modeller Region
-XLSX Import/Export
I suppose it depends on the previous version of your SMath Studio (I've not noticed issues updating from the latest Nighlty Build). Simply uninstall them and download the most recent from the extensions Manager. If you still have issues let me know and I'll update the broken plugins.
-Script Region
It is because the plugins are compiled using not compatible APIs. Recompile your plugins using the new SMath Studio libraries.
Andrey Ivashov 9/17/2015 7:44:00 PM
#5 Posted: 9/17/2015 11:52:26 AM
Your custom plug-ins must be recompiled in order to support this version of SMath Studio.
As I see Script Region is a third-party plug-in with closed sources. If its sources will be published to https://smath.info/svn/public/plugins/ - then it will be possible to support new versions of the program automatically. But for now you should ask developers to recompile it directly.
Best regards, Andrey Ivashov.
#6 Posted: 9/17/2015 12:09:55 PM
Latest changes added to the post.
Regards.
Davide Carpi 9/17/2015 12:17:00 PM, Radovan Omorjan 9/17/2015 1:17:00 PM
#7 Posted: 9/17/2015 7:24:37 PM
Rafael H Padilla Velázquez
4 likes in 4 posts.
thanks a lot!
I really love this wonderful software!
#8 Posted: 9/17/2015 7:43:49 PM
Glad to hear! Many thanks for your support!
#9 Posted: 9/18/2015 1:46:26 AM
1,555 likes in 1,867 posts.
About Script Region. I didn't have time to publish the source code. Now I need find it and publish.
Andrey Ivashov 9/18/2015 6:59:00 AM
#10 Posted: 9/30/2015 7:16:32 AM
RAJED MAGLINTE
RAJED MAGLINTE
0 likes in 4 posts.
As always, thank you Andrey. I really appreciate your efforts.
#11 Posted: 10/15/2015 2:17:16 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
I see a cloud version (link) ... what happened to the portable version? Are there any plans to do a portable version again? That's what I like to use!
#12 Posted: 10/30/2015 8:36:18 AM
mmushref
mmushref
0 likes in 1 posts.
Excellent!
I like this software. Are you going to update the Pocket PC version for more features?
#13 Posted: 12/6/2015 6:27:29 PM
anon1811
anon1811
0 likes in 1 posts.
Thank you for the update and all the hard work! I also still use Windows Mobile and would highly appreciate an update for it.
#14 Posted: 1/20/2016 1:55:30 PM
corradolvr
corradolvr
1 likes in 19 posts.
Back in Aug of 2014 I had downloaded a package SMath and Maxima. It just runs from the folder without having to install. It's very convenient and I take it with me everywhere. I would like to update to the newest version. Is there anyway I can keep it in this same easy to carry package?
#15 Posted: 1/28/2016 11:23:56 AM
Ruben Sidranski
Ruben Sidranski
It appears that you have the latest version. MKraska is the current keeper of the unofficial portable version (I am still hoping for an official one again)
https://smath.com/wiki/SMath%20with%20Plugins.ashx still shows 11/16/2014 as being the latest.
