new version errors
new version errors - Messages
#1 Posted: 2/4/2014 5:58:22 AM
kaaden
kaaden
0 likes in 13 posts.
Hello
Since I tried to install the new version I get the following error
I have reinstalled version 4909 but still appear LoaderExcepstions errors at startup and the snippets are not users / local / programs ... they are in the folder (x86) Installation Smath
thanks
#2 Posted: 2/4/2014 7:23:20 AM
kaaden
kaaden
I can't work with matrix function
#3 Posted: 2/4/2014 7:33:59 AM
1,442 likes in 2,935 posts.
Can't reproduce - Win7 x64/SMath 0.96.5146
Could you attach a file that doesn't work for you?
#4 Posted: 2/4/2014 7:47:38 AM
kaaden
kaaden
I can´t do that, the same error with matrix
I'm working with 4909 version, but it occurs since I tried install 5146
My windows is W7 professional /64
#5 Posted: 2/4/2014 7:56:34 AM
Ok...
I can suggest you only to create a simple file to post here or to send an e-mail to the developper with the file (sometimes the bug comes from other functions/plugins/settings).
As additional hint you can try to delete the "%APPDATA%\SMath\extensions\plugins" folder and the "Program Files(x86)\SMath\Plugins" folders before installing the 5146 version...
#6 Posted: 2/4/2014 8:08:41 AM
kaaden
kaaden
http://en.smath.info/forum/yaf_postst2112_-SOLVED--HRESULT--0x800700C1.aspx
the same error, ok
SOLVED, unnistall with GEEKS, now it works fine with 4909 version
thanks
#7 Posted: 2/8/2014 3:54:16 AM
2,335 likes in 4,031 posts.
This issue appeared because of unmanaged Win32 (x86) plug-in installed for 64-bit platform. All you need to do to fix this issue - to close SMath Studio and remove all plug-ins installed before.
This was found by uni (thank you!) and together we found a permanent solution.
This will not happen anymore with next version of SMath Studio (plan to release it before next week).
4 users liked this post
IVR 2/8/2014 4:21:00 AM, Вячеслав Мезенцев 2/8/2014 5:09:00 AM, Davide Carpi 2/8/2014 6:52:00 AM, ioan92 2/8/2014 2:53:00 PM
