1 Pages (11 items)
Elements Data - Properties of periodic table - Messages
#1 Posted: 4/30/2022 5:36:22 PM
Can not guarantee accuracy or correctness of data.
Properties collected form various sources and rearranged for Smath.
Do you think would it be beneficial to write a plugin for this database?
Or would this import matrix is enough for anybody for any work?
elements.zip (9.01 KiB) downloaded 497 time(s).
#2 Posted: 4/30/2022 8:09:22 PM
Some years ago I made an SMath sheet for Ashby material property charts, which also had an external database (from the companion materials of a book). Look some posts further down to find an improved version.
The actual chart was produced using Maxima, because the Ashby charts are usually loglog. The program suffers from the known problem with character encoding in recent SMath versions.
If lin-lin is ok, the graphics part could be made using XY-plot plugin. Also, there is no need for the bubbles, as your data doesn't have ranges.
Anyways, it is fun to play around with the properties to display and find out correlations.
#3 Posted: 5/2/2022 10:04:39 PM
I recall a MathCad 15 worksheet "Molecular Weights" that, if/when converted, would be a nice addition in SMATH as well.
Best regards,
Norm
Best regards,
Norm
#4 Posted: 5/3/2022 2:04:03 AM
WroteI recall a MathCad 15 worksheet "Molecular Weights" that, if/when converted, would be a nice addition in SMATH as well.
Best regards,
Norm
Hi Norm. maybe you find interesting this post: https://en.smath.com/forum/yaf_postsm66837_Balancing-chemical-equations.aspx#post66837
It is for balancing chemical equations, but has a function for calculating the mass compound too.
#5 Posted: 5/3/2022 11:04:58 AM
#6 Posted: 5/3/2022 3:00:20 PM
Hi Norm. I can't reproduce the error.
#7 Posted: 5/3/2022 5:27:21 PM
Hummm! Strange! When I turn Auto Calculate off then there is a solution. Once re-calculated, it fails. Can you send me your latest worksheet?
Thank you,
Norm
Thank you,
Norm
#8 Posted: 5/3/2022 8:46:21 PM
WroteHummm! Strange! When I turn Auto Calculate off then there is a solution. Once re-calculated, it fails. Can you send me your latest worksheet?
Thank you,
Norm
Hi Norma. That is the last version I developed.
ChemBal v2.pdf (350.12 KiB) downloaded 1283 time(s).
ChemBal v2.sm (143.06 KiB) downloaded 1767 time(s).
I simply added that I could recognize the notation "·" in chemistry with respect to the previous one, and I don't know if ions too, I don't remember well. The little program doesn't have strange or far-fetched elements, it uses the dn_LinAlgSVD plugin to obtain the nullspace array and the code to obtain the elements of a compound is not really from Mathcad, but rather one in visual basic that I had in an excel macro, but handles text as usual. If you have many vectorizations and summations, and perhaps some of them do not please SMath very much, In addition, it is strange that it does not work in auto calculation, but it does. The truth is that I hardly ever work with auto calculation on.
#9 Posted: 5/3/2022 10:59:50 PM
Thanks Alvaro,
Unfortunately, when I recalculate the sheet, the ChemBal(R) fails; "Index was outside the bounds of the array"
Norm
Norm
#10 Posted: 5/4/2022 12:57:11 AM
WroteThanks Alvaro,
Norm
Hi Norm. This version is pluginless, using it's own routine for get the SV Decomposition, and seems that works in SMath in the cloud:
https://en.smath.com/cloud/worksheet/y4ZHBgHG
#11 Posted: 5/4/2022 8:57:09 AM
Thanks Alvaro! File ChemBal_NR works!
Best regards,
Norm
Best regards,
Norm
1 Pages (11 items)
