Stable: SMath Studio 0.99.7610 (01 November 2020) - Messages
Changes introduced in current build 0.99.7610
Improvements
- Program start up speed significantly improved;
- The following units added: klx, μT, mT, klm, μWb, mWb;
- Toolbox icons vectorized;
- Cloud: SVG icons for toolboxes in supported now;
- Better support implemented for OS dark mode.
Corrections
- Support for high dpi systems restored;
- importData() function improved to support special chars in path;
- Ohm unit representation fixed for Russian localization;
- Android: Scaled images supported now;
- Android: Filling in a text is fixed for some onscreen keyboards;
- Working with images on Linux fixed (save/open, copy/paste);
- Color of the underlined text corrected;
- Text which contains link shown underlined again;
- Toolbox icons made visible on Mono;
- Export to PDF fixed on Linux;
- Cloud: All units/function selection fixed into insert dialog;
- Splash screen layout fixed on Linux.
Miscellaneous
- Worksheets rendering quality normalized between Mono and .Net frameworks;
- Refactoring.
Download
SMathStudioDesktop.0_99_7610.Mono.tar.gz (1.42 MiB) downloaded 38931 time(s).
SMathStudioDesktop.0_99_7610.Setup.msi (2.29 MiB) downloaded 90575 time(s).
- Desktop (Windows):
Framework: .NET Framework 2.0 or higher - Desktop (Linux):
- [ARA] Arabic / العربي
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Article.Eng.pdf (Date: 23.09.2009. File size: 828.96KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.IOFiles.Article.Eng.pdf (Date: 27.09.2009. File size: 453.24KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.NumericFunctions.Article.Eng.pdf (Date: 18.10.2009. File size: 622.45KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Programming.Article.Eng.pdf (Date: 18.10.2009. File size: 411.74KB) - to open in Adobe Acrobat Reader
SMath Studio icons (
SMathStudio.Icons.zip (Date: 12.04.2010. Size: 63.74KB)
- efi
- dislin
- matlab c++
- octave c++
- probe properties
Regarding efi: I'm looking at the issue right now.
WroteI see that the following plug-ins handles 0 (zero) functions now:
- efi
- dislin
- matlab c++
- octave c++
- probe properties
Prode Properties: You need to install Prode first. The plugin is just a wrapper.
Matlab C++ Math Library: For x32 only, but I have one idea how to make x64 support available.
Mathcad EFI: Also only for x32, but it is possible to make x64 support.
DISLIN: The library itself has recently been updated. I will try to update the plugin by changing the way the functions are loaded.
Octave C++ Math Library: Also only 32-bit Octave library exists.
Edit: Nevermind, I have posted a solution for this.
https://en.smath.com/forum/yaf_postsm67797_Maple-Tools.aspx#post67797
I'm struggling with installation, unfortunately there is some error that I can't solve. I checked .NET Framework, try to reboot but it appears everytime. I'm working on Win 10 x64 ver. 1809
Is there somebody who might have an idea how to resolve it?
Older versions of SMath also struggles with the same problem ;/
Thanks for help
