Opening a .xmcd file in SMath Studio
Opening a .xmcd file in SMath Studio - Error message - Messages
#1 Posted: 7/30/2015 6:40:42 AM
SteveG021
SteveG021
0 likes in 2 posts.
Morning,
I get an error message wehen opening a Mathcad .xmcd file in SMath Studio.
I have Mathcad V14 and SMath Studio V0.97 (built:5346).
I have attached an image of the error message.
Some of the file is converted propoerly but i have an issue with the IF functions.
I have attached the mathcad file which i need converted as well.
Thanks
Steve
API RP2A-WSD - SMath.sm (72.21 KiB) downloaded 1380 time(s).
#2 Posted: 7/30/2015 9:07:31 PM
Ernesto
Ernesto
13 likes in 74 posts.
Wasn't this addressed in your last post (http://en.smath.info/forum/yaf_postst4702_If-statements.aspx#post23827) ??
The problem was in your "max" function in section 1.8. "max" function needs to have the arguments inside a matrix, to have it in the format you have (arguments separated by a comma) you have to use the "Max" function. Capital and lowercase makes a difference.
You have several "min" functions with the same issue (Section 1.5 and 1.6), where it needs to be changed to "Min".
