[SMath Viewer] Variables not defined
[SMath Viewer] Variables not defined - Can't close the executable editing an empty variable - Messages
#1 Posted: 3/5/2014 1:19:17 PM
When an executable contains a variable not defined, when you edit the variable value and you press the enter key, then you can't close the executable.
Best regards,
Davide
MOVED IN THE BUG TRACKER
viewer.7z (315.51 KiB) downloaded 762 time(s).
