eval() and for/while loops
eval() and for/while loops - Messages
#1 Posted: 5/28/2012 12:32:39 PM
another little bug, I think...
bug eval() vs loops
note that the results are right (also for bigger scripts inside the loop)
here is the file in the example: bugs%2feval_for_0.94_debug.sm.zip
regards,
w3b5urf3r
#2 Posted: 5/28/2012 8:26:29 PM
Edward Ulle
Edward Ulle
21 likes in 182 posts.
w3b,
I can't explain the error but I don't understand the eval()s. eval() is the same as "=".
Ed
#3 Posted: 5/29/2012 12:15:51 AM
Hi WizEd
eval() speeds up the calculations (<10 seconds vs 20,30 seconds or minutes, if i remove all eval()s from entire script... i don't know how, but works :d )
regards,
w3b5urf3r
#4 Posted: 5/29/2012 1:14:28 PM
1,364 likes in 2,281 posts.
I am not sure if that is a bug or a feature. My theory on eval is that it enforces immediate evaluation when used on the right hand side of assignment operations. In your example, however, there is no assignment of the eval result. eval just tries to evaluate the statements inside the line operation and as a last step tries to determine the return value of the line operation (which is normally the value of the last line).
The last line, in your case, is a for statement, which is just a flow control statement and seems not to have a return value on it's own. Therefore, the last line has no return value and eval complains.
I may be totally wrong, still just providing any other line at the end resolves the error message.
eval(for)
Best regards, Martin Kraska
Radovan Omorjan 5/29/2012 2:41:00 PM
#5 Posted: 5/29/2012 6:11:53 PM
hi mkraska,
Thank you! I agree with your analysis
probably the use of eval() in the left side is not conventional, however the error message is quite obscure, I think o_o ...
for the visual error I had done differently, moving the eval() inside the for loop... in addition to eliminating the red border seems to be slightly faster, although I do not understand why (hundreds of eval() instead of one...)
best regards,
w3b5urf3r
