1 Pages (9 items)
Special Plots On 2D Plot Bug - Special Plots do not appear when using "if...else" domain argument - Messages
#1 Posted: 3/21/2022 12:00:29 PM
I have found a low priority issue where special plots (e.g. text shown on the 2D plot) do not appear on the 2D plot when using an "if...else" domain definition. The Special Plots do show up if I use boolean domain definitions, however.
I have attached a sample file here that should make it clear.
I also tried submitting this to the bug tracker, but it appears I do not have the privileges to log into the bug tracker system.
Thank you!
SpecialPlotsBug.sm (8.83 KiB) downloaded 1627 time(s).
Thank you!
#2 Posted: 3/21/2022 2:23:30 PM
#3 Posted: 3/21/2022 2:53:55 PM
WroteI have found a low priority issue where special plots (e.g. text shown on the 2D plot) do not appear on the 2D plot when using an "if...else" domain definition. The Special Plots do show up if I use boolean domain definitions, however.
Thank you!
You can use cases() in Custom Functions Plugin for that purpose.
Plotting, solve(), roots(), FindRoot() and various commands may don't like if/else.
Sometimes an error can be fixed by using a line(), not in your example though.
Recursive functions doesn't solve when line() and cases() used both, etc etc.
These are bitter tricks/bugs, I tend to forgot them everytime.
After struggling a while however I remember the "correct usage".
#4 Posted: 3/21/2022 6:30:37 PM
Would be interesting, why if() is not defined by default as boolean expression just like cases().
Is there any use case, where the original if() is better than the one defined with cases()? If not, then I propose to include re-definition of if() in the custom functions plugin.
![2022-03-21 22_18_08-SMath Solver - [SpecialPlotsBug.sm_].png](/en-US/files/Download/ZRkZwF/2022-03-21-22_18_08-SMath-Solver---[SpecialPlotsBug.sm_].png)
sergio 3/22/2022 5:48:00 AM
#5 Posted: 3/21/2022 8:20:41 PM
Bolean bug(s) are user bug.
Many projects will accommodate either style if/else ... if/otherwise
A long suite of conditions is horror if/else.
Doctor your plot 1 as proposed, press F9
Integrate Discontinuous_1.sm (24.57 KiB) downloaded 1599 time(s).
Integrate Discontinuous.sm (36.51 KiB) downloaded 1644 time(s).
Integrate Discontinuous_2.sm (132.47 KiB) downloaded 1639 time(s).
#6 Posted: 3/21/2022 9:57:44 PM
#7 Posted: 3/21/2022 10:21:45 PM
Wrote...
Hi Martin. Yes. Here one: https://en.smath.com/forum/yaf_postsm34552_Custom-Functions-plugin.aspx#post34552
and here the Davide answer about that: https://en.smath.com/forum/yaf_postsm34559_Custom-Functions-plugin.aspx#post34559
I also remember some other about what complex could be the expressions in cases(), but can't found that.
sergio 3/22/2022 6:05:00 AM
#8 Posted: 3/22/2022 9:26:54 AM
... doctored for convenience.
Observe collected plot, easy to manage.
Cheers ... Jean.
SpecialPlotsBug DOCTORED.sm (10.86 KiB) downloaded 1622 time(s).
Cheers ... Jean.
#9 Posted: 3/22/2022 11:42:00 AM
1 Pages (9 items)
