Disable specific unit
Disable specific unit - How to disable not used unit - Messages
#1 Posted: 4/23/2018 10:18:16 AM
m227
m227
4 likes and 1 dislikes in 29 posts.
Hi, in my calculations I often use kJ/kg (and derivative) units (enthalpy, specific heat).
SMath always presents result in Gy and I have always manually to redefine it.
Is there any possibility to disable Gy unit which is useless for my tasks?
I tried to assign 'Gy := 0 to disable this unit but it does not work.
#2 Posted: 4/23/2018 10:42:17 AM
Work sheet would help.
Unitless solves all problems.
Knowing in advance the unit of result, define it user style
kJ/kg ... Smath style kJ_kg:=1
copy "kJ_kg", paste in the empty place holder of result.
#3 Posted: 4/23/2018 1:09:38 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
When you re-defined Gy, did you use the ' infront of Gy (e.g. 'Gy? This makes it the same font/etc.
I work in IP units and need to re-define everything in the results. Part of the quirks of working in SMath
#4 Posted: 4/23/2018 2:40:46 PM
#5 Posted: 4/27/2018 7:38:08 AM
m227
m227
Hi, I would like to have something without need of definition new auxiliary variables. Just to disable a single unit...
Here is my sample which is automatically recalculated to unwanted Gy:
#6 Posted: 4/27/2018 8:45:21 AM
1,359 likes in 2,273 posts.
btw, the default unit depends on optimization setting.
symbolic evaluation gives bare SI base units.
numeric evaluation gives some derived unit, which might or might not be appropriate for the given case.
#7 Posted: 11/8/2018 3:44:26 AM
Ganzman
Ganzman
0 likes in 2 posts.
I have to agree with m227. Can we request this as a feature as Gy is hardly applicable in most cases.
#8 Posted: 11/8/2018 8:02:36 PM
1,138 likes in 1,805 posts.
Hi. This is a workaround. Edit the file Units.xml under the SMath/entries/ folder, disabling the entries for the unit Gy:
Then you can get, for example, the enthalpy from Coolprops plugin in J/kg by default:
frapuano 11/9/2018 6:54:00 AM
#9 Posted: 11/8/2018 8:35:48 PM
Ganzman
Ganzman
0 likes in 2 posts.
Much obliged!
