1 Pages (9 items)
Analog Clock - A simple animation - Messages
#1 Posted: 7/9/2013 10:24:35 AM
4 users liked this post
ioan92 7/9/2013 11:21:00 AM, Вячеслав Мезенцев 7/11/2013 1:12:00 PM, Andrey Ivashov 7/10/2013 8:27:00 AM, Fridel Selitsky 7/9/2013 2:27:00 PM
#2 Posted: 7/9/2013 4:51:49 PM
Beautiful animation: To reduce the computation time can be operators "for", which do not depend on time, move out of the function cloc (s).
Best Regards,Ber7.
AnalogClock1.sm (22.29 KiB) downloaded 1403 time(s).
Best Regards,Ber7.
#3 Posted: 7/9/2013 5:20:04 PM
Thank you ber,
this make the script faster and easier to read
Best regards,
Davide
P.S. worksheet updated
Best regards,
Davide
#4 Posted: 7/11/2013 5:37:01 AM
Davide,if your program to change the settings a bit, we get
"real" analog clock (all the arrows are moving continuously).
Best Regards,
Ber7
AnalogClock2.sm (21.44 KiB) downloaded 1467 time(s).
Best Regards,
Ber7
#5 Posted: 7/11/2013 8:49:18 AM
I see, wonderful
#6 Posted: 7/16/2019 12:08:53 AM
#7 Posted: 7/18/2019 2:24:18 PM
Cheers to all!
This is my 5 cents to this thread. I only took some pieces of code from here and there, a little bit of make up, and.. voilá: my version of analog clock that works on "real" time
Updated 19jul2019 (Special thanks to [USERLINK]Razonar[/USERLINK]):
Annoying "purple line" eliminated. Path for sound files fixed. More realistic movement of hands clock.
MyClock2.sm (38.86 KiB) downloaded 1354 time(s).
click_low.wav (171.1 KiB) downloaded 357 time(s).
alarm.wav (891.03 KiB) downloaded 367 time(s).
#8 Posted: 7/19/2019 2:25:06 AM
Hola Oscar. Very nice effects.
You can improve it multiply Play() by 1000 or something else but big. This avoid the horizontal purple line in the clock.
Also you define the location of the files as "D:\sound.wav". Using 1000*Play("sound.wav" ) searches sound in the same directory of the SMath file.
Finally notice that your blue hours hand jumps between hours, but not follow the actual movement of an hours hand clock. You need to take 1/2-1/6*el(NOW,1)-el(NOW,2)/600 as the arguments for sin, cos functions for place it between exact hours considering the minutes too.
#9 Posted: 7/19/2019 6:15:08 PM
WroteHola Oscar. Very nice effects.
Thanks for your suggestions
I've updated the file and I uploaded the new one, you can check it here.
1 Pages (9 items)
