Solve() function with units
Solve() function with units - Solve() with units - Messages
#1 Posted: 1/27/2023 8:51:24 AM
Thomy
Thomy
0 likes in 5 posts.
I can't find the error. I want to solve a simple linear equation for a static problem. But with the solve() function i can't enter units. Problem.JPG
it says not real roots.
Thanks for help
#2 Posted: 1/27/2023 11:19:01 AM
I can't find the error. I want to solve a simple linear equation for a static problem. But with the solve() function I can't enter units.
Generally, solve blocs aren't units compatible.
Attach the document for possible doctoring.
#3 Posted: 1/27/2023 12:11:37 PM
Thomy
Thomy
0 likes in 5 posts.
Hello
You can find the file in the attachment
#4 Posted: 1/27/2023 12:27:22 PM
1,138 likes in 1,805 posts.
There is no "solve block" there. For the real ones there is a plugin. In any case, there is a function to find roots, which is compatible with the use of units, you just have to know how to use it and in what cases. For this function, the roots function seems more suitable instead of solve. Try with this, for example
#5 Posted: 1/27/2023 12:39:17 PM
Thomy
Thomy
0 likes in 5 posts.
Doesn't work. The File is in the attatchment.
Thanks you very much
#6 Posted: 1/27/2023 12:55:43 PM
Doesn't work. The File is in the attachment. ...
Hi. I can't find the file.
#7 Posted: 1/27/2023 1:00:31 PM
Thomy
Thomy
0 likes in 5 posts.
Fixpunkte LIWA.sm (4.24 MiB) downloaded 1524 time(s).
#8 Posted: 1/27/2023 1:04:41 PM
Hi. It works in my environment. Try with F9 for update the calculation.
#9 Posted: 1/27/2023 2:37:16 PM
NO file attached !!!
#10 Posted: 1/27/2023 7:20:52 PM
1,359 likes in 2,273 posts.
In your initial post, just replace solve() by Solve(). This requires the Maxima Plugin being installed.
It is a symbolic solver, which has generic unit handling, i.e. the unit of the result is determined by the solver.
An alternative is the FindRoot function, where you have to provide an initial guess (starting point for the numeric solver) and the result is automatically assigned to the variable.
The maxima solver returns an equation variable=solution, which can be converted into an assignment by the Assign() function. More details to be found in the handbook (Google SMath Handbuch).
#11 Posted: 2/3/2023 12:27:57 PM
Thomy
Thomy
0 likes in 5 posts.
How can i install the MaximaPlugin. Do i have to integrate the maxima folder in the plugin subfolder from SMath?
#12 Posted: 2/3/2023 3:20:16 PM
Follow the link in my signature (points to the wiki). There you find instructions.
