Animation of mechanisms
Animation of mechanisms - Ber7 - Messages
#21 Posted: 7/27/2012 11:31:39 PM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Drilling a square hole (Cross section of the drill is Reuleaux triangle)
Reuleaux triangle is rotated around its center of gravity, and the center of gravity
moves around the center openings.
https://smath.com/wiki/GetFile.aspx?File=Reuleauxtriangle.rar
Davide Carpi 7/28/2012 12:50:00 PM, ioan92 5/18/2013 7:48:00 AM
#22 Posted: 8/5/2012 3:13:02 AM
Fridel Selitsky
Fridel Selitsky
Drilling accurate (without rounding) square hole
The disc in the form of a modified Reuleaux triangle
moves inside a square frame . A drill (green dot in the center
of the yellow circle) makes an exact square hole.
References:
Wagon S. Mathematica in Action: Problem Solving .
Through Visualization and Computation,Springer, 2010
https://smath.com/wiki/GetFile.aspx?File=Drilling2.rar
3 users liked this post
Davide Carpi 8/5/2012 12:09:00 PM, ioan92 5/18/2013 7:48:00 AM, Andrey Ivashov 8/5/2012 7:49:00 AM
#23 Posted: 8/13/2012 3:19:53 PM
Fridel Selitsky
Fridel Selitsky
Square-Hole Drill (continued)
Using the coupling Oldham to convert the rotational motion
of the drive shaft to move the tool to the square trajectory.
https://smath.com/wiki/GetFile.aspx?File=SquareHole.rar
Davide Carpi 8/14/2012 5:20:00 AM, Andrey Ivashov 8/14/2012 6:01:00 PM, ioan92 5/18/2013 7:48:00 AM
#24 Posted: 8/13/2012 3:23:14 PM
Fridel Selitsky
Fridel Selitsky
Davide Carpi 9/22/2012 7:36:00 PM, ioan92 5/18/2013 7:49:00 AM
#25 Posted: 8/16/2012 10:41:24 AM
Fridel Selitsky
Fridel Selitsky
Drill, coupled with the Reuleaux triangle
ioan92 5/18/2013 7:49:00 AM, Davide Carpi 8/22/2012 9:17:00 AM
#26 Posted: 8/22/2012 7:48:08 AM
Fridel Selitsky
Fridel Selitsky
Wankel Engine((rotary-Reuleaux triangle)
Wankel.rar (2.74 KiB) downloaded 613 time(s).
ioan92 5/18/2013 7:49:00 AM, Andrey Ivashov 8/22/2012 12:40:00 PM, Davide Carpi 8/22/2012 9:17:00 AM
#27 Posted: 9/22/2012 12:07:33 PM
Fridel Selitsky
Fridel Selitsky
Chassis for Mars Curiosity Rover
Soft landing "Curiosity" on the surface of Mars was held August 6, 2012
https://smath.com/wiki/GetFile.aspx?File=Curiosity.rar
ioan92 5/18/2013 7:49:00 AM, Davide Carpi 9/22/2012 7:36:00 PM
#28 Posted: 10/29/2012 6:19:16 AM
Fridel Selitsky
Fridel Selitsky
Rocker-bogie mechanism that can navigate the stairs.C.M.-center of mass.
1.All three wheels are actuated independently.
Climbimg1.rar (4.15 KiB) downloaded 622 time(s).
ioan92 5/18/2013 7:50:00 AM, Davide Carpi 10/29/2012 7:15:00 AM
#29 Posted: 10/29/2012 6:25:44 AM
Fridel Selitsky
Fridel Selitsky
2. All three wheels are passive and the part of the rocker-bogie mechanism body is pulled
up by the external force as in the case of shopping carts.
Climbing2.rar (4.17 KiB) downloaded 584 time(s).
Davide Carpi 10/29/2012 7:15:00 AM, ioan92 5/18/2013 7:50:00 AM
#30 Posted: 11/17/2012 6:27:27 AM
Fridel Selitsky
Fridel Selitsky
Planar three-link manipulator
3R.rar (60.06 KiB) downloaded 534 time(s).
Davide Carpi 2/3/2013 6:04:00 PM, ioan92 5/18/2013 7:50:00 AM
#31 Posted: 1/7/2013 12:58:35 PM
Fridel Selitsky
Fridel Selitsky
Geneva Mechanism
Geneva.smz (40.39 KiB) downloaded 1806 time(s).
Davide Carpi 1/7/2013 1:21:00 PM, ioan92 5/18/2013 7:51:00 AM
#32 Posted: 2/3/2013 2:26:51 PM
Fridel Selitsky
Fridel Selitsky
Animation kinematic characteristics
Above: The trajectory of the point B, the vectors of its velocity and acceleration;
Below: the dependence of the velocity and acceleration of point B on
crank angle β (t)
kinchar1.sm (37.74 KiB) downloaded 1502 time(s).
kinchar.smz (11.6 KiB) downloaded 1768 time(s).
ioan92 5/18/2013 7:51:00 AM, Davide Carpi 2/3/2013 6:04:00 PM, Martin Kraska 2/3/2013 5:08:00 PM
#33 Posted: 2/4/2013 10:55:13 AM
sublim21
sublim21
3 likes in 36 posts.
Impressive stuff Ber.
#34 Posted: 5/18/2013 6:21:16 AM
Fridel Selitsky
Fridel Selitsky
Robot snake
Worm1.smz (15.36 KiB) downloaded 1676 time(s).
ioan92 5/18/2013 7:51:00 AM, Davide Carpi 5/18/2013 7:31:00 AM, Andrey Ivashov 5/18/2013 5:56:00 PM
#35 Posted: 9/28/2013 2:45:33 AM
lrcvs
lrcvs
3 likes in 2 posts.
Hi,Ber7
All your post for moving parts are very, very, very...., goods, fantastics.!
Fridel Selitsky 9/29/2013 10:23:00 AM
#36 Posted: 1/17/2014 6:23:24 AM
Fridel Selitsky
Fridel Selitsky
Animation spatial mechanisms
To calculate the position of the mechanism will use
techniques developed A.B.Ivanov.His work on 3d
animation mechanisms made ​​in Mapl, publishes A.B.Ivanov
online
http://forum.exponenta.ru/viewtopic.php?t=12842
Of the examples from this site I suffered in a programming environment SMath Studio
1. Sarrus linkage 1
Sur111.smz (8.13 KiB) downloaded 1738 time(s).
Davide Carpi 1/21/2014 6:08:00 PM
#37 Posted: 1/17/2014 6:27:14 AM
Fridel Selitsky
Fridel Selitsky
2. Sarrus linkage 2
Sur3.smz (9.82 KiB) downloaded 1797 time(s).
Davide Carpi 1/21/2014 1:14:00 PM, Martin Kraska 1/21/2014 6:48:00 PM
#38 Posted: 1/21/2014 1:14:15 PM
Nice job ber, as usual
BTW I can't download the first animation (Sarrus linkage 1)
Best regards,
Davide
#39 Posted: 1/21/2014 3:50:29 PM
Fridel Selitsky
Fridel Selitsky
Thank you,Davide,now you can download the file.
#40 Posted: 10/4/2016 3:07:34 PM
Fridel Selitsky
Fridel Selitsky
Sarrus.sm (19.25 KiB) downloaded 1624 time(s).Sarrus linkage
Short animation program
