Bad Unit?
Bad Unit? - Long Ton v. Tonne v. Short Ton v. British Ton... - Messages
#1 Posted: 6/5/2025 9:10:38 PM
⚜ Kenny Lemens, P.E. ᵂᴵ
85 likes in 179 posts.
Greetings,
I just want to verify something quick: is 'tonne calibrated to the wrong value? If this is supposed to be a Long Ton, then I would've thought the value to be 2,240 lbm, but I'm seeing it as 2,204 lbm.
May this be of Good Help;
#2 Posted: 6/6/2025 8:33:10 AM
1,438 likes in 2,924 posts.
tonne in SMath it is defined as 10^3 kg that should be 2204,62 lbm
Wolfram: https://www.wolframalpha.com/input?i=1000+kg
Google: https://www.google.com/search?q=1000+kg+to+lbm
Edited 6/6/2025 8:34:20 AM
Andrey Ivashov 6/6/2025 10:01:11 PM, ⚜ Kenny Lemens, P.E. ᵂᴵ 6/6/2025 10:07:10 PM
#3 Posted: 6/6/2025 10:06:55 PM
Greetings,
You are correct; tonne is defined correctly. The "long ton (British ton)" is 2,240lbs; I was under the misunderstanding the British Ton and the Metric Tonne were the same unit of mass.
#4 Posted: 6/7/2025 10:27:55 AM
Better to always double check the units conversions .
There's also a short ton aka US ton; both short and long tons are defined as 1 ton =20 hundredweight, but the hundredweight is defined differently in US (100 pounds) and in Britain (112 pounds).
Edited 6/7/2025 10:28:14 AM
⚜ Kenny Lemens, P.E. ᵂᴵ 6/16/2025 8:39:41 PM
