More vector-producing vector results
More vector-producing vector results - mfos - Messages
#1 Posted: 10/20/2013 4:19:55 PM
mfos
mfos
0 likes in 4 posts.
This is a little similar to my last post, but different enough to warrant its own post. However, it might help to solve both.
The easiest way to put this, is that I am getting 2 - 4 sized vectors for reasonably complicated equations. However, on major simplification, I have whittled one down to the following:
#2 Posted: 10/20/2013 4:43:28 PM
1,355 likes in 2,271 posts.
Can you attach a screenshot of your settings under Tools> Options> calculations or the relevant settings from your settings file (as found in SettingsDirectory())? And perhaps include any of the mentioned equations?
#3 Posted: 10/20/2013 4:51:45 PM
mfos
mfos
0 likes in 4 posts.
This was solved in the previous post ("Square Root Result" ). Turns out it was the same issue.
Thanks anyhow!
