Vectorize Issue: How to Get 2D Matrix Output?
Vectorize Issue: How to Get 2D Matrix Output? - Messages
#41 Posted: 4/22/2022 4:12:10 PM
Download Kirby NIST data set ... fit.
I will correct your defective design.
Just that one for learning step.
#42 Posted: 4/22/2022 4:25:13 PM
598 likes in 1,380 posts.
Yeah, you should learn there is no such thing as kW/hr.
Unit of power is kW, it is written as kilowatt. No time involved.
And poise is the unit of dynamic viscosity. (Pa*s) or (kg/m*s)
In pump calculation you should use stokes. (m^2/s)
#43 Posted: 4/22/2022 4:51:42 PM
Mark R Harris
Mark R Harris
4 likes in 90 posts.
It would have been a really fast learning step if SMath's units were used from the outset.
Time for an apology and a retraction (SI units being unsuitable for process control) Jean, me thinks.
This has not been pleasant to watch.
#44 Posted: 4/23/2022 7:53:59 PM
Yes Mark, adapt project system/standards,
accordingly to the Control Engineer Tool Box ... standards
Nothing dogmatic/Bible.
Cheers ... Jean.
Mark R Harris 4/23/2022 8:01:00 PM
#45 Posted: 4/23/2022 8:05:34 PM
Mark R Harris
Mark R Harris
Cheers ... Jean.
Excellent, thanks Jean.
It may be worth doing some weeding to remove examples that may lead noobies astray.
