wrong handling of units
wrong handling of units - Measure Units - Messages
#1 Posted: 5/2/2018 11:03:27 AM
jaguar3
jaguar3
0 likes in 4 posts.
I have a problem. Why does Gy or J appear near tonne?
NH.3_ex_c_r:NH.3_ex_c*M.ex_c=1227.6454 Gy tonne
NH.3_ex_c_r:NH.3_ex_c*M.ex_c=1.2276*10^6 J tonne
#2 Posted: 5/2/2018 12:37:53 PM
Arie
Arie
94 likes in 285 posts.
Hi Adis,
We'll need more information to help you. could you please post the .sm file you're referencing?
#3 Posted: 5/2/2018 4:23:48 PM
"tonne" reminds me a Mathcad bug in the German version.
It also appeared in the Mathsoft "Fourier model" English US version.
#4 Posted: 5/3/2018 4:47:19 AM
jaguar3
jaguar3
0 likes in 4 posts.
Hi Adis,
Proiect master MB1.sm (38.93 KiB) downloaded 1412 time(s).
#5 Posted: 5/3/2018 7:11:31 AM
In your file I can't find neither NH.3_ex_c nor M.ex_c
#6 Posted: 5/3/2018 7:34:53 AM
jaguar3
jaguar3
0 likes in 4 posts.
Sorry wrong files.
Problem.sm (105.05 KiB) downloaded 1420 time(s).
Real result is 1.2276 tone. 1 tone = 1000 kg
#7 Posted: 5/3/2018 11:03:34 AM
Arie
Arie
I think i fixed the issue. See attached.
I have disabled some of your manual unit definition and performed some cleanup.
Generally you do not want to overwrite units already defined within Smath and you were re-defining already defined units.
The issue, I believe came with your definition of H.ii_c. You applied units to the result and toggled ignore units. This made it seem like the result evaluated to kJ/kg when in fact it was unitless.
This propagated through to the result in question.
Problem_alyles.sm (120.74 KiB) downloaded 1427 time(s).
#8 Posted: 5/3/2018 11:33:53 AM
Above my head ! why do we still have tonne ?
For God sake what's that in Smath ?
What was it in Mathcad ?
What is the difference between "Titration and MassBalance" ?
In case of interest, PseudoInverse works fine in Smath.
Matrix PseudoInverse.sm (111.21 KiB) downloaded 1438 time(s).
#9 Posted: 5/3/2018 11:40:41 AM
Arie
Arie
1 tonne is defined as 1000 kg. Same thing as a Mg.
#10 Posted: 5/3/2018 12:12:18 PM
Thnks alyless,
ton(long), ton(short), tonne(metric)
#11 Posted: 5/3/2018 1:05:51 PM
ton(short)
short is t
#12 Posted: 5/4/2018 1:10:03 AM
jaguar3
jaguar3
0 likes in 4 posts.
Thank you very much! The original file was worked in Mathcad. After conversion to SMath Studio, some errors occurred. In the future, I will only use the defined units.
#13 Posted: 5/4/2018 1:26:54 AM
Oh !, you are the man of science in there.
I know about titration from past professional [Process Control & Instrumentation]
Not so easy ... so and so ... generally Ph control.
Did you visit PseudoMatrix ? Any use for your project ?
