Beam calculation
Beam calculation - Ber7 - Messages
#1 Posted: 11/19/2011 4:24:17 PM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
https://smath.com/wiki/GetFile.aspx?File=Beam.rar
Oscar Campo 11/19/2011 11:33:00 PM
#2 Posted: 11/20/2011 10:51:08 AM
Fridel Selitsky
Fridel Selitsky
https://smath.com/wiki/GetFile.aspx?File=Cantilever.rar
#3 Posted: 11/20/2011 10:51:45 AM
Edward Ulle
Edward Ulle
21 likes in 182 posts.
Ber7,
You amaze me with your use of graphics in SMath. I'm a civil engineer and use SMath for calculations just like this but without the pictures.
Could you post your SMath sheet in a zip file so I can see how you do it? I don't use RAR. Thanks.
Ed
#4 Posted: 11/20/2011 3:42:36 PM
Fridel Selitsky
Fridel Selitsky
Ed
https://smath.com/wiki/GetFile.aspx?File=Cantileverzip.zip
https://smath.com/wiki/GetFile.aspx?File=Beamzip.zip
#5 Posted: 11/20/2011 4:41:50 PM
Edward Ulle
Edward Ulle
Ber7,
Your animations and drawings always amaze me. Thanks.
Ed
#6 Posted: 11/21/2011 5:38:01 AM
Fridel Selitsky
Fridel Selitsky
https://smath.com/wiki/GetFile.aspx?File=Contin%5d.zip
#7 Posted: 11/24/2011 5:06:47 AM
Fridel Selitsky
Fridel Selitsky
https://smath.com/wiki/GetFile.aspx?File=ElastFound.zip
#8 Posted: 4/3/2012 7:14:42 PM
olik
olik
3 likes in 27 posts.
Hello.
This is very nice. I am civil ingenieer & I will use it. Thanks.
However it is dangerous to use the function x>Lf.
I found it out in my own beam programming.
When changing direction of concetrated forces, the graph of shearing force has to jump once up & once down.
And for the following input it does not!
It seems to me, the function x>Lf does not work correctly each time.
Regards Olik
SMath files: beam 3 & 4.zip
Fridel Selitsky 4/4/2012 2:12:00 AM, Andrey Ivashov 4/4/2012 2:05:00 AM
#9 Posted: 4/3/2012 7:20:59 PM
kmihaylovich
kmihaylovich
8 likes in 131 posts.
Olik, try to change x>Lf to eval(x>Lf).
Fridel Selitsky 4/3/2012 10:49:00 PM, olik 4/4/2012 1:55:00 PM
#10 Posted: 4/3/2012 10:52:33 PM
Fridel Selitsky
Fridel Selitsky
Thank you, kmihaylovich, the file is corrected.
Regards,Ber7
#11 Posted: 4/4/2012 2:04:53 AM
2,343 likes in 4,044 posts.
Thank you! This is already fixed and will work correctly even without eval function into the next SMath Studio release.
Regards.
#12 Posted: 4/4/2012 1:58:31 PM
olik
olik
Thanks to all. The eval function seems to be a good way.
And if You fix this little bug, it will be the best.
Regards, Olik
#13 Posted: 1/15/2013 1:20:31 PM
Fridel Selitsky
Fridel Selitsky
Single moving load
AnimBeam.smz (6.25 KiB) downloaded 1694 time(s).
Davide Carpi 1/15/2013 2:02:00 PM, Oscar Campo 1/15/2013 3:29:00 PM
#14 Posted: 2/14/2013 11:35:46 AM
Fridel Selitsky
Fridel Selitsky
The load moves in deflection curve
AnimBeam1.smz (6.09 KiB) downloaded 1585 time(s).
Davide Carpi 2/14/2013 1:40:00 PM
#15 Posted: 3/20/2013 6:20:44 PM
Fridel Selitsky
Fridel Selitsky
Beam on elastic foundation.Movable load
MoveEl.smz (8.49 KiB) downloaded 1658 time(s).
Davide Carpi 3/20/2013 8:58:00 PM
#16 Posted: 6/11/2013 5:10:10 AM
Fridel Selitsky
Fridel Selitsky
Graphics with shading
(http://en.smath.info/forum/resource.ashx?a=1691)
AnimBeam2.sm (38.63 KiB) downloaded 1577 time(s).
4 users liked this post
Вячеслав Мезенцев 6/11/2013 12:00:00 PM, ioan92 6/11/2013 5:58:00 AM, IVR 6/11/2013 12:39:00 PM, Davide Carpi 6/12/2013 7:18:00 PM
#17 Posted: 6/12/2013 11:05:41 AM
Fridel Selitsky
Fridel Selitsky
Cantilever-new edition
https://smath.com/wiki/GetFile.aspx?File=CantileverENExe.rar
CantileverEN.smz (18.82 KiB) downloaded 1703 time(s).
ioan92 7/3/2013 4:23:00 PM, Davide Carpi 6/12/2013 7:19:00 PM
#18 Posted: 7/2/2013 3:55:17 PM
Fridel Selitsky
Fridel Selitsky
Beam with a variable distance between the supports
BemAnim.smz (15.6 KiB) downloaded 1588 time(s).
3 users liked this post
ioan92 7/3/2013 4:23:00 PM, Andrey Ivashov 7/3/2013 5:19:00 PM, Davide Carpi 7/2/2013 4:44:00 PM
#19 Posted: 7/6/2013 2:29:47 PM
Fridel Selitsky
Fridel Selitsky
Analysis of statically indeterminate beam. Supported cantilever.
Beam fixed at the one end supported an the other
https://smath.com/wiki/GetFile.aspx?File=Konsol%2bopora.rar
Konsol+opora.smz (134.15 KiB) downloaded 1696 time(s).
IVR 7/7/2013 2:46:00 PM, Davide Carpi 7/6/2013 6:31:00 PM
#20 Posted: 2/11/2021 3:32:36 AM
Egidijus
Egidijus
0 likes in 2 posts.
Hello, could somebody help me. I don't understand how to solwe this problem.
