wrong axis labels in plot2d
wrong axis labels in plot2d - Messages
#1 Posted: 8/29/2013 1:21:44 PM
1,353 likes in 2,264 posts.
In the 2D plot region, I observed a tick label (number) to switch from the correct value (8) to zero for special scaling values. Even if there is XY-Plot region if nice labeling matters, this might be worth a fix.
#2 Posted: 8/29/2013 4:56:21 PM
Hmm...can not reproduce this,
#3 Posted: 8/29/2013 5:52:22 PM
1,442 likes in 2,934 posts.
Is not a bug, just an eye-trick due to a combination of font-size, line thickness and line position; if you move the grid or you zoom your page you can see the trick (plot not evaluated)
best regards,
Davide
Martin Kraska 8/29/2013 9:32:00 PM
#4 Posted: 8/29/2013 9:32:11 PM
Thanks for pointing this out. Then the remedy is easy: change the z-order of the objects (grid to bottom). I did not note that the grid is in front of the tick labels.
#5 Posted: 8/30/2013 6:55:02 AM
I agree, should be the easiest solution
