Long Equations
Long Equations - Separate Equation - Сообщения
#1 Опубликовано: 05.10.2022 14:31:14
Thilo Schönherr
Thilo Schönherr
Hello there,
i have an short question. Is it possible to separate long equations so that they fit in the sheet width (A4)?
I would like to continue using the same font size for a good look. :d
Best Regards, Thilo
#2 Опубликовано: 05.10.2022 16:16:50
churichuro
churichuro
28 сообщений из 79 понравились пользователям.
yes & no
look this :
you position yourself with the cursor on the operator (+,-,*,/) where you want to section your equation, and press the CTRL-M key combination
#3 Опубликовано: 05.10.2022 18:47:02
Oscar Campo
Oscar Campo
You position yourself with the cursor on the operator (+,-,*,/) where you want to section your equation, and press the CTRL-M key combination
Does It suppose that CTRL-M creates a Matrix?
#4 Опубликовано: 05.10.2022 18:58:38
churichuro
churichuro
yes, must be CTRL-ENTER, excuseme.
Oscar Campo 05.10.2022 19:26:00, Jason McCool 05.03.2024 11:27:00
#5 Опубликовано: 06.10.2022 12:07:37
Thilo Schönherr
Thilo Schönherr
Hi churichuro,
thank you very much.
It works in normal equations but not in loops.
