Levenberg-Marquardt Edu.
Levenberg-Marquardt Edu. - Levenberg-Marquardt Edu. - Сообщения
#1 Опубликовано: 16.10.2018 10:39:41
Thanks again Uni for your profitable implementation of LM.
About "T" [ThermoCouple}: You will find that from nowhere except if NIST has
updated their stuff from original Mathcad [2003], as well as Kirby2.
Kirby2 & "T" demonstrate the most common Y/X data reduction.
Type "T" T/C covers nearly the all cryogenic range, very rugged vs Pt100.
As given, it fits NBS 125. You can personalize your own "T" by simulating
the fixed points from some good test bath ... won't be as accurate.
Genfit al_ nleqsolve.sm (243,07 КиБ) скачан 1187 раз(а).
