Chras when save
Chras when save - Smath stopped working whan I try to save - Сообщения
#1 Опубликовано: 30.03.2015 05:59:28
Gilba
Gilba
I deal with a 50 pages static report. Everithing went fine, until an SMath crash. After that I had to repair my file by XML editor, to close some command. I could open it, and continue the work. But now I can not even save! If I just modify something, and try to save, Smath crashes. Is it too big? Only 2 MB!
sm file: https://www.dropbox.com/s/wsk5j9pxc8fh1uf/AluBridge.sm?dl=0
Does anyone have a sollution?
It would be quite urgent!
Thanx!
#2 Опубликовано: 30.03.2015 08:35:48
Gilba
Gilba
Hi Ioan!
Thanx for your fast reply, yes that's what I just also did. Split the files. I don't know yet how to deal with this communication between files, I'll check what you sent.
Thanx again!
