Mathcad 14 files to Latex
Mathcad 14 files to Latex - Сообщения
#1 Опубликовано: 01.11.2016 12:00:03
MJK
MJK
I have a bunch of long Mathcad files that I would like to insert to a Latex document as an appendix. It is not possible with mathcad as it does not support latex files.
Is there by any chance a way to convert mathcad files to latex through SMath studio?
MK
#2 Опубликовано: 02.11.2016 00:26:05
What is the point to convert a piece of working maths in dead maths
in all sorts of non convertible stuff [Given/Find, symbolic ...]
On the other hand, it would be like "reverse Engineer a propriatary software".
Do a lot better: select the Mathcad parts, copy, paste in IrfanView,
copy from IrfanView, paste in Wingrab, reduce colors 256.
Collect/plug in your appendix. All those transits take < 10 sec.
Result: absolute quality.
#3 Опубликовано: 02.11.2016 07:38:18
1 440 сообщений из 2 929 понравились пользователям.
If you are able to open the files correctly in SMath, then you can try with Data Exchange] plugin; once it is installed you can save the document as XeLaTeX file (File > Save as...)
If you want/need to create a pdf manual, handbook, etc... is not bad to have text and math as vector objects, that can be rendered/printed at any resolution without loss of quality; even the text parts are much better if they can be selected to be copy/pasted.
#4 Опубликовано: 06.03.2017 10:33:17
ArtificialTruth
ArtificialTruth
MK
I've written a program to convert most of the type of math in Mathcad 15 files. Untested for 14 files.
May help you?
Still in alpa
https://github.com/ArtificialTruth/PTC-Mathcad-to-LaTeX-parser
