Root of an equation?
Root of an equation? - Сообщения
#1 Опубликовано: 19.07.2011 09:35:44
abustillos
abustillos
1 сообщений из 4 понравились пользователям.
Hello, I would appreciate your help.
I have an f(x) function with x as the variable. I then gave x a value and I am trying to define a new value finding the root of the f(x).
Which function should I use to find the root? I do not find it in the functions menu?
Thanks.....Adriana
#2 Опубликовано: 19.07.2011 15:18:44
Edward Ulle
Edward Ulle
21 сообщений из 182 понравились пользователям.
Adriana,
Try the solve function.
[LIVE width=275 height=312]http://smath.info/live/?file=2943[/LIVE]
There is considerable discussion of the limitations of solve() on the forum so if you encounter any problems try searching the posts.
Good luck.
Ed
