.sm File corrupted with no error message
.sm File corrupted with no error message - Сообщения
#1 Опубликовано: 15.05.2017 16:43:52
sdfms
sdfms
I have done a calculation on a retaining wall, which suddenly has become corrupted. Smath will open the file, but won't display most of it. The last pages are missing, and there is just a red error dot on the last page (see pic)
Показать спойлер
Stottemur.sm (491,35 КиБ) скачан 1441 раз(а).. Is it somehow possible to restore this?
#2 Опубликовано: 15.05.2017 17:14:58
Here you are:
Stottemur_Kr.sm (491,24 КиБ) скачан 1405 раз(а).
#3 Опубликовано: 15.05.2017 17:17:39
sdfms
sdfms
That is amazing, thank you so much, you really saved me a lot of time there!
#4 Опубликовано: 15.05.2017 17:50:11
Smath is capricious with some plugins. If an image region has not completed
[right or wrong], most likely Smath will not save and will file 0 kb. That
is because an image region is resident in the work sheet, therefore: if
not done nothing to save. In your document, you had an empty "Writer region"
in red. Delete it, bingo => your document is 100 % there.
#5 Опубликовано: 16.05.2017 13:06:11
sdfms
sdfms
Thanks for the explanation. Is there any way to easily find empty regions like that?
#6 Опубликовано: 16.05.2017 15:11:45
It is an issue solved with the latest beta version, so you can upgrade and simply open the file with that version; if you won't update to a beta version you can still use the beta just to to open and save the file, then open this file with your stable SS.
#7 Опубликовано: 16.05.2017 20:34:31
Is there any way to easily find empty regions like that ?
"empty region": you mean an unspecified/not filled region.
Up to now, I never noticed Smath sending some region anywhere
in the work sheet. Mathcad 11 would [once in a while] send
region [usually a dead region] pages'sss down, pages'sss right.
In Smath, past the last region, next page is blank [blue].
