Two Overhang Beam with UDL
Two Overhang Beam with UDL - Moment diagram Problem - Сообщения
#1 Опубликовано: 20.02.2023 11:33:13
yoswos
yoswos
I have attached a mathcad file.. and the moment diagram at the end doesn't match
with expcted output.. it should have gone smoothly to end with x coordinate 5m.
but at certain point it has jumped to postive rigion.
Please help fix it.
Thanks
#2 Опубликовано: 20.02.2023 17:05:51
I have no idea why mathcad plots that segment faulty.
But it is possible to plot correct graphic in SMath.
However SMath integration is not very good and fast.
It will take much more time than mathcad, and zig-zagy.
You can improve plot by increasing Integrate: Accuracy.
It is in Tools>Options>Calculation.
PS: I increased accuracy to 500 to get a decent plot.
It took 50 seconds to plot in the picture!!
Integration should really be improved.
UDL.sm (18,08 КиБ) скачан 1420 раз(а).
#3 Опубликовано: 20.02.2023 18:14:20
In the interactive handbook you can find examples for beam analysis.
They use symbolic integration and equation solving with Maxima. This is very fast, except for the Maxima restart at the beginning of the sheet (can be removed if all works well).
Показать спойлер
example maxima beam.sm (41,78 КиБ) скачан 1943 раз(а).
#4 Опубликовано: 21.02.2023 02:35:40
yoswos
yoswos
Sorry but I have problem again
with M(5m)=-0.2083 kN m
it should have been
M(5m)=0
#5 Опубликовано: 21.02.2023 02:42:21
yoswos
yoswos
it should have been
M(5m)=0
My sorry it is correct.. since it is overhang it should have moment at the end;;
#6 Опубликовано: 21.02.2023 02:49:22
Though it should be smaller. Probably zero by the way.
Result can be reduced with integral accuracy set to 10000.
SMath integral algorithms are not good enough.
#7 Опубликовано: 21.02.2023 04:46:08
Hi. Remembering that solving an ODE is also told to integrate it:
UDL.sm (22,97 КиБ) скачан 1402 раз(а).
The domain can also be restricted to M(x) by multiplying it by the corresponding inequalities.
Вячеслав Мезенцев 21.02.2023 07:54:00, NDTM Amarasekera 21.02.2023 11:27:00
#8 Опубликовано: 21.02.2023 10:02:18
Finite Differences [FD] is a very good yardstick insensitive to noise.
It that what you mean moment at the end ?
Cheers ... Jean.
Page2 FD.sm (57,85 КиБ) скачан 1592 раз(а).
#9 Опубликовано: 21.02.2023 11:29:30
This is a marvelous solution.
I learned a new thing today.
Thanks Razonar.
Maybe I am wrong but I think formula should be like this.
Huge kN*m values appear if calculated as in the picture above.
Alvaro 21.02.2023 14:49:00
#10 Опубликовано: 21.02.2023 12:55:20
ODE integrator(s) range from exact [rarely]
approx. 4 decimals ... to glorious freak !
64 bits Smath does not have 32 bits Matlab ODE.
Recently checked on my PC2 this damned bug.
Cheers ... Jean.
ODE 0 TEST [17].sm (45,27 КиБ) скачан 1159 раз(а).
Revisit from few months ago.
#11 Опубликовано: 21.02.2023 14:51:56
Huge kN*m values appear if calculated as in the picture above ...
Hi overlord. You're absolutely right. Thanks for catching that error. Only 3 orders of magnitude. Who could worry about that? The Mathcad block can also be used, although I don't know if this is the best way to deal with the units, using an intermediate function Mo.
UDL.sm (26,96 КиБ) скачан 1388 раз(а).
