Trace Graph like Mathcad
Trace Graph like Mathcad - Is there anything like this? - Сообщения
#1 Опубликовано: 15.02.2025 03:17:59
RegRetired
RegRetired
8 сообщений из 143 понравились пользователям.
Does SMATH have the ability to click on a value in a graph plot to retrieve the x and y values?
This feature in Mathcad is very useful to find specific values.
For example, I would like to know the exact y value when x = 400 ppm on this graph.
Thanks
Reg
Reg CurryLoveland, CO
#2 Опубликовано: 15.02.2025 05:46:14
francesco rapuano
francesco rapuano
15 сообщений из 38 понравились пользователям.
Hi Reg,
I guess that Davide is working on a plugin that can address your need, See this post.
Franco
#3 Опубликовано: 15.02.2025 09:31:16
RegRetired
RegRetired
Thanks Franco,
I’ll check it out. In the meantime time linterp is a reasonable workaround.
Reg
#4 Опубликовано: 15.02.2025 15:09:19
francesco rapuano
francesco rapuano
Or you need to use Engauge but it is obviously something not in the Smath environment.See link here
Franco
