Thank you for your quick comment, but I think that when you see complex numbers in the roots of the polynomial it may mislead you in the correctness of the solution. Honestly when I counter check with ti-89 it gave me complex roots too, but in a friend Hp 50g gave me correct roots {1,1,-1}. You are correct the algorithm used appears to be companion matrix.
