Problems with opening mathcad files
Problems with opening mathcad files - Сообщения
#1 Опубликовано: 05.07.2016 15:33:55
Stefan Müller
Stefan Müller
0 сообщений из 45 понравились пользователям.
Hey anyone can provide me how i can open my mathcad files with smath. The plugin is not working. I can not open the full mathcad File in smath.
Thx always get an error message:-(
#2 Опубликовано: 05.07.2016 15:42:07
Hello soletto, the answer is still the one provided some days ago here.
I see you deleted the bug report, this doesn't help to fix the issue because no report = no starting point to investigate the issue.
I've restored it, since it doesn't contains sensible data.
Stefan Müller 05.07.2016 15:53:00
#3 Опубликовано: 05.07.2016 17:17:17
Stefan Müller
Stefan Müller
OK thx. I answered my question.
Its about the mathcad and smath syntax . Is a little bit different.
I solved the problem. I think so....
#4 Опубликовано: 05.07.2016 19:31:06
Good, however as stated in the other thread it is just matter of teaching the plugin to recognize the xmcd schema to translate it into smath objects (that may be working stuff if there is an equivalent, or dead functions alternatively).
#5 Опубликовано: 05.07.2016 22:36:20
Hello, Solletto,
Though I have no interest in Mathcad 15 [my latest was 11.2a]], I would be curious to see
an image of that piece of Mathcad 15 and its equivalent code interpreted by the Smath Plugin.
