Smath issue with exp as matrix
Smath issue with exp as matrix - Сообщения
#1 Опубликовано: 24.12.2024 23:32:05
Cornel
Cornel
2 сообщений из 78 понравились пользователям.
#2 Опубликовано: 25.12.2024 00:36:45
NDTM Amarasekera
NDTM Amarasekera
Is this OK ? I am not sure.
#3 Опубликовано: 25.12.2024 00:37:52
Matrix exponential is not implemented.
You can replicate in SMath what the Maxima engine does with the vecotrize() function (otherwise by default SMath tries to perform a scalar operation and fails).
#4 Опубликовано: 25.12.2024 00:42:44
Cornel
Cornel
But still the SMath result is not the same as the Mathcad result...
#5 Опубликовано: 25.12.2024 00:54:48
Cornel
Cornel
I think it's because as Davide said, Matrix exponential is not implemented in SMath. But then how to calculate the Matrix exponential in SMath? There is a way somehow?
#6 Опубликовано: 25.12.2024 11:57:40
Oscar Campo
Oscar Campo
This is the answer via wolfram alpha:
Is the same obtained via vectorize function on SMath. Maybe your file or configuration on Mathcad have some parameters you are not mentioning?
Alvaro 25.12.2024 13:24:00, Davide Carpi 25.12.2024 16:55:00
#7 Опубликовано: 25.12.2024 13:29:01
Hi Cornel. The exponential function is a well-defined function from the complex plane into the complex plane. A possible extension to its domain and range being square matrices analogous to the ordinary exponential function can be defined as e^A = sum(A^k, k=1...infinity). And notice that this is valid only for square matrices, not for the general case.
In general, the other CASs have special functions for this extension of the exponential function: expm in matlab, MatrixExp in wolfram mathematica, exponential in maple and matrixexp in maxima, which you can access from SMath:
mat-exp.sm (13,45 КиБ) скачан 1652 раз(а).
So I guess if it is right for the developers of maxima, maple, mathematica and matlab to distinguish between both functions and to have specific instructions for each of them, then doing so in SMath is right, regardless of what the developers of mathcad think.
Oscar Campo 25.12.2024 16:13:00, francesco rapuano 25.12.2024 16:47:00
#8 Опубликовано: 25.12.2024 13:37:45
Cornel
Cornel
Ok, understood. This was the thing I was looking for. Thank You.
#9 Опубликовано: 26.12.2024 00:06:22
It seems there is also MatrixExponential in newer maple versions.
I tried to solve this problem using maple plugin by its library with(LinearAlgebra) command in maple, but couldn't prevail.
Old LinearAlgebra library lacks this particular command. Then you posted this solution.
#10 Опубликовано: 26.12.2024 00:26:14
Cornel
Cornel
If it were possible to update from maple 6 to the latest version of maple...then would be great to stay up to date with the latest maple engine and with his latest available capabilities, but i understood that this is not possible..right?
#11 Опубликовано: 26.12.2024 00:35:01
It's possible, but not as part of a plugin. I don't use maple often, so I'm too lazy to spend time on it.
#12 Опубликовано: 26.12.2024 00:44:16
Cornel
Cornel
But how to use then the latest maple engine If it's possible?
From my point of view If someone can make possible to use every time the latest version of maple engine in SMath then it would rise a lot SMath
And If You dont use often maple 6, then what you use? Maxima?
#13 Опубликовано: 26.12.2024 00:50:35
Cornel
Cornel
@uni there is also wolfram engine for developers FREE to use...but how to integrate this in SMath?
See below:
https://writings.stephenwolfram.com/2019/05/launching-today-free-wolfram-engine-for-developers/
And this wolfram engine for developers it's updated as latest wolfram mathematica engine, even though the article is from 2019
#14 Опубликовано: 26.12.2024 01:18:29
Cornel
Cornel
Maybe someone can announce, call or tell somehow to the SMath owner to integrate wolfram engine in SMath..
