Unified Soil Classification System USCS
Unified Soil Classification System USCS - spreadsheet - Сообщения
#1 Опубликовано: 31.08.2023 16:30:44
Fabian Valencia Villaquiran
5 сообщений из 3 понравились пользователям.
Attached is a spreadsheet to classify the soil according to USCS and the granulometric curve is plotted by sieving.
Please upload any improvements done to this file and post if any mistakes are found or if you have any suggestions.
This is the original code.
USCS1.sm (101,6 КиБ) скачан 1865 раз(а).
This is the original code with another particle-size distribution
USCS.sm (103,17 КиБ) скачан 2267 раз(а).
Below in another post it is updated with a better presentation of the granulometric curve.
João Felipe Seráfico Melo 31.08.2023 23:41:00, Alvaro 01.09.2023 01:11:00, sergio 01.09.2023 05:03:00
#2 Опубликовано: 06.09.2023 10:14:07
Fit & explorer ... Jean
USCS fit Granulometry.sm (21,61 КиБ) скачан 1786 раз(а).
#3 Опубликовано: 07.09.2023 01:23:17
Thank you so much,
I added the logistic sigmoid function you made to the initial code and it compare with and without the fit. In addition to the initial curve, I graphed it using the Zed Graph, where it can be better appreciated using a semilogx graph
USCS-fit-Granulometry.sm (175,97 КиБ) скачан 1679 раз(а).
#4 Опубликовано: 08.09.2023 15:07:51
Thank you so much,
Thanks as well, very educative.
A large suite of math codes added
Cheers ... Jean.
Project USCS fit Granulometry.sm (90,24 КиБ) скачан 1794 раз(а).
