6179 Observed Inconvenience
6179 Observed Inconvenience - 6179 Observed Inconvenience - Сообщения
#1 Опубликовано: 11.01.2017 00:07:26
While revising all my 5346 work sheets, opening one by one in 6179,
I observed two things [unrecovered regions]:
1. One particular work sheet, the first plot had "data" from plotG(,,,,,)
6179 opens w/o the data:=plotG(,,,,,) ... the plot is red [easy to recover]
2. Another work sheet, the XY data set is data:= [two cols]
X:=col(data,1)
Y:=col(data,2)
6179 returned:
X:=col(Data,1)
Y:=col(data,2)
No problem to recover these two cases, but the question is
why it misses some region and why it alters other region ?
#2 Опубликовано: 11.01.2017 06:45:35
1 441 сообщений из 2 931 понравились пользователям.
Hello Jean,
are you sure that the issues they haven't been on/before saving? (in practice, we can notice the differences you listed above opening the same file with SS 0.97 and SS 0.98?)
