Engineering evaluation
Engineering evaluation - need for better graphing ... - Сообщения
#1 Опубликовано: 30.11.2015 13:20:40
Teacher
Teacher
1 сообщений из 20 понравились пользователям.
Hi there,
I'm an mechanical engineer dealing with many different design layout problems.
Request #1:
A I often have to do is displaying internal force systems alont a part. Though the given functions are just piecewise defined and the trailing variable is starting every time new.
Up to now I do the graphing "by hand" in just defining the results point to point .... Woould be nice to get a more easier way to do so ...
Request #2:
Is'nt it possible to intergate the XY-Plot plugin and enhance it a little bit in
- giving it a more friendly GUI for modifying the way of displaying the results
- giving it the possibility to draw an vector-array (4xn) like
(V1x.start, V1y.start, V1x.end, V1y.end
V2x.start, V2y.start, V2x.end, V2y.end
Request #3:
Sometimes I need to display 3D-Surfaces and Vectors. The scope of doing so in SMath are very litte, so it would be great to improve it!
Hope that I'm not the only one who is in need of those things ...
#2 Опубликовано: 30.11.2015 17:06:32
Ernesto
Ernesto
13 сообщений из 74 понравились пользователям.
For Request 1,
Have you tried creating a piecewise function, and later plotting that?
#3 Опубликовано: 23.12.2015 14:44:02
_____________________________
Posting your work sheet is almost garantee to get reply.
Get inspired from the attached.
Utilities Matrix Treasury [Rotate].sm (48,29 КиБ) скачан 1362 раз(а).
Utilities [Plot points on Trace].sm (13,08 КиБ) скачан 1416 раз(а).
Integrate Discontinuous.sm (24,9 КиБ) скачан 1501 раз(а).
Utilities XY plot.sm (16,5 КиБ) скачан 1548 раз(а).
LGC Logistic.sm (37,77 КиБ) скачан 1571 раз(а).
Utilities Quick f plot.sm (41,66 КиБ) скачан 1596 раз(а).
Contour X_Y plot.sm (55,83 КиБ) скачан 1529 раз(а).
Contour X_Y plot [More Parametric].sm (101,88 КиБ) скачан 1384 раз(а).
ioan92 23.12.2015 14:51:00, Radovan Omorjan 23.12.2015 17:37:00, Andrey Ivashov 14.01.2016 12:52:00
#4 Опубликовано: 12.01.2016 13:39:32
Teacher
Teacher
Hi there,
sorry, forgot to add example.
Here we go. Its about constructing a lever of an container vehicle.
On page 3 there are two "Bereiche" where there are different functions for the bending gear Mb and below that there is a Diagramm...
Container Vehicle.doc (768,5 КиБ) скачан 989 раз(а).
calculations.sm (844,92 КиБ) скачан 1586 раз(а).
#5 Опубликовано: 13.01.2016 13:09:57
Ernesto
Ernesto
There are only 2 pages to this document, there is no page 3. please repost
#6 Опубликовано: 09.04.2016 18:20:44
Teacher
Teacher
Hi, sorry I just posted the tasks not the calculations .... So I've done that now in the addition to the post abovs.
