the issue with imaginary numbers in equations answers
the issue with imaginary numbers in equations answers - Сообщения
#1 Опубликовано: 26.02.2020 11:15:45
Вуаутвук
Вуаутвук
0 сообщений из 11 понравились пользователям.
Some of my answers include "і" signs, what should I do to get a regular answer?
At first, I thought it was a problem in the cosine equations but later saw the same problem in other formulas.
TROPtaKhV_Lb2.sm (356,86 КиБ) скачан 1200 раз(а).
#2 Опубликовано: 26.02.2020 11:31:50
"i" indicates that this is a complex number with an imaginary part.
It is completely normal for the cases you have exposed since the square root of a negative number does not make sense in the real field (it is a complex number); in the same way, the arc-cosine makes sense in the real field only for numbers less than or equal to 1
Вуаутвук 27.02.2020 07:00:00
#3 Опубликовано: 26.02.2020 11:40:55
literal 'l' is too confusing, use λ [Greek]
imaginary 'i' and ordinary 'i' are not compatible
especially in for loop... please check.
TROPtaKhV_Lb2 Test back.sm (356,86 КиБ) скачан 1206 раз(а).
