Program for Linear and Polynomial Fit - Сообщения
Hope this document will tranquilize visitors/users !
Jean.
If that's what you think.
WroteIf that's what you think.
Does it work for you ... SS 7251 users please confirm ?
WroteWroteIf that's what you think.
Hello Jean
Yes, It works
WroteOriginally Posted by: MarB [url=/forum/yaf_postsm60156_Program-for-Linear-and-Polynomial-Fit.aspx#post60156][/url]If that's what you think.
It works. Thank you MarB.
WroteThat's my solution
- to separate the functions from matrix building,
- to use vectorize for speed
Apparently, the function f(#x):=1 if n=0 has a problem?. Or is it redundant?
For values n>0, the "otherwise" condition yields correct results irrespective of values in "if" condition.
Please check.
just put the 1 into a 1x1 matrix. That's all.
(And if you want to use units with the X Vector, just remove the eval and evaluate symbolically.)
WroteWroteThat's my solution
Please check.
Wrotejust put the 1 into a 1x1 matrix. That's all.
Hi
Still the same error when n=0.
Better if you can post the SM file please.
Sorry, I didn't realize, that vectorize behaves unexpectedly (to me), when the function does not include 'x'.
So I changed f to f(x):=[1+0*x] and now it works. The file is attached.
PolyFit.sm (11,92 КиБ) скачан 1238 раз(а).
I would expect the results of g and h to be the same, and to be a 3 items long vector.
sergio 12.12.2019 16:13:00
Hi
Now I get same results as yours.
But the result (19.0833) of the Polyfit() function when n=0 ----> Does it have any meaning?
I have no idea. I was only testing it for all possible conditions..
Cheers MarB.
Note: Incidentally, 19.0833 happens to be the Mean of Y vector.
Cheers MarB.
IMHO ... no need to complicate matters.
Modular design is easier to fix.
More automated is OK if you intend to poly for the entire Planet.
PolyFit (2).sm (46,79 КиБ) скачан 1270 раз(а).
Hi. This is in case you want to interpolate with an horizontal line.
PolyFit.sm (159,33 КиБ) скачан 1284 раз(а).
PolyFit.pdf (748,27 КиБ) скачан 793 раз(а).
sergio 12.12.2019 16:12:00
Thank you, Alvaro.
