how to use the "system of equations" function
how to use the "system of equations" function - Сообщения
#1 Опубликовано: 31.12.2021 22:44:30
John
John
0 сообщений из 12 понравились пользователям.
Hi, guys:
I'm a new one to SMath. and have a question on system of equations.
here is a simple question
how to get the result of x, y without using the matrix? I tried solve and findroot, but can't get the value of x, y.
Thank you for the help
Happy New Year!
#2 Опубликовано: 01.01.2022 07:59:32
You can't use solve() for nonlinear equations. (more than one unknowns)
You can use roots(), FindRoot() or al_nleqsolve().
Here is your equation solved in various ways.
solvers.sm (10,77 КиБ) скачан 1317 раз(а).
#3 Опубликовано: 01.01.2022 10:17:57
how to get the result of x, y without using the matrix ?
Matrix style is more commonly encountered in Engineering projects.
That add-on will enrich your future projects.
#4 Опубликовано: 01.01.2022 11:22:51
John
John
Excellent reply!
FindRoot is better for my condition, I need units.
Thanks Overlord!
#5 Опубликовано: 01.01.2022 11:25:11
John
John
Thank you, Jean, you're right, I need more practice.
#6 Опубликовано: 01.01.2022 15:38:12
That example has only one CAS route ... naturally 15 D.
#7 Опубликовано: 01.01.2022 20:24:17
John
John
Thanks! Jean
