1 страниц (5 вхождений)
Speed up a program - Сообщения
Some numbers can not be calculated for D().
Iteration doesn't concluded because "≉".
I have replaced it with an epsilon.
To plot it is better you eliminate units.
X-Y plot can but 2D plot cannot plot with units.
I had to put plot under an eval().
PreClean_fast.sm (63,85 КиБ) скачан 1482 раз(а).
Valery Ochkov 22.12.2023 10:09:00
Hi. Just use the recent Davide solution: Ctrl-A for select all, right mouse click and choose numeric optimization. The calculus is done in less than one second.
