1 страниц (7 вхождений)
How to plot a (simple) equation (and choose interval)? - Сообщения
Sorry for this newbie question.
Assume I entered a super simple equation like:
y=2*x
Now I want to plot this graph/function in interval [-10,10]
How can I do this?
When I right-click on the equation I expected a context menu entry like "plot".
But there is no such context menu.
How else can I achieve this?
Peter
y=2*x
How can I do this?
Peter
I should add a section on plotting in tutorial.
Insert> Plot> 2D
The axes control is via mouse wheel scrolling (try shift and ctrl keys) and panning
Insert> Plot> 2D
1. Shift+@ to get the plot canvas
2. enter the plot argument
3. Shift+Wheel mouse [shrink/expand X directions]
4. Ctrl+wheel mouse [shrink/expand Y directions]
5. Mouse left down to slide in either directions
6. once the initial default plot is done:
... click on plot, mouse wheel to zoom ± both directions
2D Plot Range.sm (8,9 КиБ) скачан 1994 раз(а).
2D Plot Range.sm (8,9 КиБ) скачан 1478 раз(а).
2D Plot Range CONSTRAIN.sm (12,93 КиБ) скачан 1499 раз(а).
2D Plot Range CONSTRAIN demo.sm (24,12 КиБ) скачан 1434 раз(а).
Insert> Plot> 2D
Ok, thank you.
However I would like to have this function available as context menu of an entered function the paper.
Could this be added in the next version?
WroteHowever I would like to have this function available as context menu
Can you explain/exemplify ...
Do you mean: click on the plot for a drop down options menu ?
... there is a missing detail from all examples and tutorials.
The Smath 2D default plot is on the X/Y ranges ± 10.
By default as well, it plots on the canvas pixel
i.e: 96 ppi [Pixel per inch], thus the extremely fine trace,
much finer than Mathcad that plots on ½ pica [6 ppi].
If you want to set intervals otherwise: construct 2D discrete.
Egyptians had it their own ways [you know that]
For long time before the Egyptians, it is believed
the Mesopotamians had it much closer from "continued fractions".
"Pi" was approximated by various long empirical approximations [Legendre ...]
"Pi" was finally proved by Schwab [1813] => isoperimetres method.
Simon Plouffe [UQAM Montréal] method is pretty new, striking of simplicity.
The question is: can we devise some infinite numerical random suite to
approximate 'Pi' ... answer is NO ! Increase 'N' not to avail.
Random Monte Carlo Pi.sm (24,78 КиБ) скачан 1407 раз(а).
