question about 2D graph
question about 2D graph - Сообщения
#1 Опубликовано: 14.06.2020 14:46:33
churichuro
churichuro
29 сообщений из 79 понравились пользователям.
hello again.
How can I get a graph from a variable? Example in graph 2 where nothing appears.
the content of the variable is pasted directly into graph 1 and
there it is working
I generate the matrices to draw a series of rectangles
but I don't know in advance how many rectangles will be drawn
that's why I require to use a variable that contains a system of several matrices
is there another solution?
stack-of-rec.sm (29,67 КиБ) скачан 1243 раз(а).
#2 Опубликовано: 14.06.2020 18:04:22
There might be other issues, but one of them could be the bug demonstrated here. Normally, no element assignment should alter the object type from list to matrix as it seems to happen in the line block definition. I think this is another regression, such stuff used to work in older versions (here 7251).
The original desparate workaround with str2num tries to handle the bug. Normally you should be able to reliably initialize a variable using any object of appropriate type.
Lists.sm (7,5 КиБ) скачан 1233 раз(а).
#3 Опубликовано: 14.06.2020 19:48:13
Transit the 'gg' matrices via file, plot.
stack-of-rec.sm (31,93 КиБ) скачан 1221 раз(а).
#4 Опубликовано: 14.06.2020 20:56:33
churichuro
churichuro
thank you very much Martin Kraska and also to you Jean Giraud
both options work well
I attach the file with Martin's suggestion, which I
It seems what I was looking for, and I take note of the solution
Jean who as always is very helpful and educational
since you learn a lot from these examples.
Thank you!
stack-of-rec.sm (23,12 КиБ) скачан 1209 раз(а).
#5 Опубликовано: 14.06.2020 21:04:19
Much simpler Amigo ...
Isolate 'gg' gg:= gg ...or rectangles:= gg
#6 Опубликовано: 14.06.2020 21:44:58
churichuro
churichuro
Hahaha yes! this work too.
#7 Опубликовано: 15.06.2020 11:39:52
If you want unicolor plot and rotation,
you may have to reconsider your construction.
Utilities XY [Draw Truss].sm (22,85 КиБ) скачан 1049 раз(а).
stack-of-rec.sm (37,11 КиБ) скачан 1222 раз(а).
churichuro 12.05.2021 13:36:00
#8 Опубликовано: 15.06.2020 13:55:02
Your H beam, you can have it SVG style.
Spline De Casteljau SVG Hbeam.sm (41,36 КиБ) скачан 1309 раз(а).
#9 Опубликовано: 15.06.2020 14:26:17
The issue demonstrated in the above post nails down to unexpected handling of single element lists used to initialize the data under numeric optimization.
lists2.sm (6,44 КиБ) скачан 1209 раз(а).
Davide Carpi 15.06.2020 15:08:00, frapuano 16.06.2020 02:45:00
