1 страниц (6 вхождений)
Thiele Function Automation - Automation of the Thiele function - Сообщения
This example is an automation of the Thiele function
published by Jean in the "Utilities Pts logpts Application" sheet
Thiele_Automatic_Jean_cbg.sm (22,08 КиБ) скачан 1290 раз(а).
WroteThis example is an automation of the Thiele function
... refreshed a bit, a note added.
Superb, the piece of automated interpolation.
Thanks Carlos ... Jean
Thiele_Automatic_Jean_cbg.sm (26,85 КиБ) скачан 1281 раз(а).
Hello Jean,
Please review the following example that you posted.
Thiele Model Construct.sm (44,15 КиБ) скачан 1306 раз(а).
Thank you
Thank you
WroteHello Jean,
Hello Carlos,
The attached document has been doctored.
The long native form is as nice to export than the reduced J_Frac.
J_Frac is more compact, but not as clear for unfamiliar user.
Thiele is capricious wrt to Maple [see the blue note].
It starts refusing if too many Maple instances have been invoked,
maybe a limited courtesy from Maplesoft ?
Please let me know if correct in your Smath system.
See you soon ... Jean
From fresh Smath session, supports the 3 documents attached.
Thiele_0 Demo.sm (57,41 КиБ) скачан 1265 раз(а).
Thiele Transit_Convert.sm (13,57 КиБ) скачан 1276 раз(а).
Thiele Model Construct Copy.sm (37,77 КиБ) скачан 1282 раз(а).
Hello Jean
Updated version of Interpolation using the Thiele algorithm in cuntinuous fractions.
It includes the calculation of the inverse differences φ [x0, ..., xi], obtained from the values in the known points
Rounding the values of the inverse differences for the purpose of presenting the equation to make it shorter
Thiele_Automatic_Jean_CBG_R1.sm (69,59 КиБ) скачан 1329 раз(а).
Hello Carlos,
What a delicious/educative/Engineering piece of work ... zillions thanks !
Reshaped a bit for first time readers.
Thiele_3 Automatic [on error Carlos].sm (36,97 КиБ) скачан 1073 раз(а).
