Snippets for Projects
Snippets for Projects - Сообщения
#1 Опубликовано: 11.11.2010 03:23:27
0 сообщений из 52 понравились пользователям.
Started playing around with snippets and I see a point for improvement:
The snippet manager does not recognize subfolders in the snippet directory. If snippets can be defined on the fly between section delimiters placed as desired within the current math sheet, it can be placed within a subfolder in the snippet directory named to reflect the current project at hand. Snippets can then be special purpose for the current project. That gives more flexibility in defining larger math sheets with "subroutines" that may not be polished, useful, or general enough for them to be a widely available snippet. This project based concept will also make organizing snippets far easier.
Peace
