if_else Exception Report
if_else Exception Report - if_else Exception Report - Сообщения
#1 Опубликовано: 11.04.2019 10:21:35
Can't make it work ... SS 6179
Please, can you quick verdict: NOT compatible
or if possible doctor the patient ?
It may have to be constructed recursive style
Thanks in advance ... Jean
Spline Bspline FAILS.sm (66,5 КиБ) скачан 1467 раз(а).
#2 Опубликовано: 11.04.2019 12:57:17
Arie
Arie
Here's something that at least evaluates on 0.99.7030. One thing to note about your function.
There isn't a "return" statement in Smath programming. A program returns the last line entry by default. So to compensate, you have to assign values to a variable and pass that variable at the end. In this case I chose "ans".
I also used "cases" function to clean things up a bit.
Spline Bspline PASSES-alyles.sm (68,51 КиБ) скачан 1415 раз(а).
#3 Опубликовано: 11.04.2019 13:36:28
Arie
Arie
I had an error some of the logic. Also updated to mimic graph that was attached.
Spline Bspline PASSES-alyles.sm (79,56 КиБ) скачан 1421 раз(а).
Spline Bspline PASSES-alyles.pdf (266,43 КиБ) скачан 948 раз(а).
#4 Опубликовано: 11.04.2019 14:28:15
Thanks Grand Doctor Alyles ... works fine.
Will refresh soon ... Jean
