Inserting/deleting matrix rows,cols
Inserting/deleting matrix rows,cols - Сообщения
#1 Опубликовано: 25.05.2012 05:20:42
One of the feature in v0.94 is inserting and deleting elements in vector/system/line. This is a very welcome feature.
From the Last changes list,
Added ability to add a new cell to the vector/system/line by keying arguments separator;
On the other hand, now you can not get into mat(..), line(..), sys(...) anymore using argument separator in order to edit - or at least I do not know how.
In the first place, I think this is better now because I experienced some unwanted behavior (sometimes SMath crashes) when I could edit those commands manually. We can now just use argument separator only to insert and backspace do delete cells.
I think now the matrix remained uncovered regarding insert/delete elements or resizing a matrix. We can do that again by copying into a text editor and changing mat(...) and pasting back to SMath or using SMath matrix editor.. I hope that in the next releases of SMath the feature of deleting/inserting rows,columns would be implemented. Actually, my intuition tells me that this is very likely to happen, sooner or later
#2 Опубликовано: 31.05.2012 03:48:11
Alstoning
Alstoning
Цитата
my intuition tells me that this is very likely to happen, sooner or later Good
Nice and I think it is ok...
