Integration problem
Integration problem - Сообщения
#1 Опубликовано: 06.08.2010 20:31:18
Waluyo Adi Siswanto
Waluyo Adi Siswanto
1 сообщений из 55 понравились пользователям.
I cannot get the answer of this integration
In Mathcad I can get 2.394
[LIVE width=308 height=209]http://smath.info/live/?file=1461[/LIVE]
#2 Опубликовано: 07.08.2010 06:28:27
Hello waluyo,
You have a singular point at the lower limit (0) - (division by zero). In SMath there is a simple Simpson based integration formula implemented at the moment. The best you can get is to use some small number instead of zero (although the result will be erronous).
I hope that some more sophisticated numerical (maybe analytical as well) integration algorithms will be implemented in SMath sooner or later.
