Форум SMath SMath Studio Questions how to change result units to normal 1 страниц (2 вхождений) how to change result units to normal - Сообщения К последнему сообщению #1 Опубликовано: 27.01.2024 22:44:39 meka1240 0 сообщений из 1 понравились пользователям. Группа: User Helloas in the title, how to change the result units to normal, previously I had normal results in integers, now the results have changed, for example (21761.554+5474.6904*i) these are electrical calculationsRegards #2 Опубликовано: 29.01.2024 22:01:45 ⚜ Kenny Lemens, P.E. ᵂᴵ 84 сообщений из 175 понравились пользователям. Группа: User Greetings, I rarely work with complex numbers, but it is work noting that SMath does have two functions:Re() = "Returns the real part of a complex number."Im() = "Returns the imaginary part of a complex number."Hopefully you can use these functions to generate the normal value you seekMay this be of Good Help;⚜ Kenny Lemens, P.E. ᵂᴵ "No matter where you go, there you are." -Buckaroo BanzaiHotkeys: https://en.smath.com/forum/resource.ashx?a=45771&b=2 1 страниц (2 вхождений) Новые сообщения Нет новых сообщений
